GridFrequency
| Last Update | 2023-07-19 |
Concept
Desired end result:
Zero cross algoritm
Algorithm for getting accurate instantaneous frequency:
Phasing algorithm
Alternative algorithm:
- Sample the mains frequency waveform at about 5000 Hz
- Correlate during 1 second with a perfect 50 Hz reference waveform, by keeping a sum of the waveform multiplied by a cosine (I) and a sum of the waveform multiplied by a sine (Q)
- After one second, calculate the phase using, atan2(Q, I). Changes in the phase compared to the previous second represent the deviation / time shift from the perfect 50 Hz frequency.
This results in:
- continuous process, with a new frequency value every second
- we use *all* of the data contained in one second, a condition for producing a robust value
- any DC offset in the mains frequency waveform is automatically balanced out, no need to keep track of the median or quartile values
Ideas
- While playing around with an STM32 blue pill, it turned out you might not need a mains power interface at all. A piece of wire picks up ambient 50 Hz already.
- Typical accuracy of the STM32 clock crystal appears a bit lower than that of the ESP8266, but for visualisation this might not be so important.
- You cannot do this with the Wemos D1 mini board (containing an ESP8266), because the A/D input has voltage-level matching resistors attached that pull it towards ground
- A raspberry pi pico appears to satisfy many requirements:
- Able to sample mains frequency directly from ambient signals on its sensitive A/D input, without the need for a transformer circuit
- Able to sample a signal with good timing accuracy, it has a crystal better than 30 ppm (0.0015 Hz at 50 Hz)
- Might allow control of a LED ring using FastLED for visualisation (not possible with STM32), to be researched
- Has WiFi support, although rather dodgy on the Arduino platform, for publishing directly to mqtt
- Relatively inexpensive
- We can probably run the stats-collecting and frequency-calculating processes in parallel, continuously.
- The frequency-calculating process can copy a snapshot of the quartile values when needed, to get a recent set, but keep decision-levels stable while running.
Visualisation
Mains waveform ring
Concepts:
Calculation:
| GND | GND | Ground |
| VCC | 5V | Powers the ZMPT101B from the wemos D1 mini |
| OUT | A0 | Analog mains waveform, 0..5V, 180 kohm resistor in series |
Luatos ESP32C3
This module (with serial chip) seems to work quite well so far:
- Senses mains waveform under some circumstances even without a wire attached, using the 'phase' software algorithm
The ADC1/UART1 RX pin is the input for 50 Hz. You can just leave that unconnected and it will pick up 50 Hz, or perhaps connect a short piece (20 cm or so) of wire to it.
To flash the esp32c3 board:
- install platformio
- check out the code
git clone https://github.com/bertrik/MainsFrequency
- enter the esp32c3phase directory
cd MainsFrequency cd esp32c3phase
- connect the board, compile and upload
- connect with serial terminal, to watch frequency measurements
pio device monitor
