StofAnanas
Revision as of 08:08, 30 April 2022 by Bertrik Sikken (talk | contribs)
Project StofAnanas
Last Update 2022-04-30
The concept
The stofananas/stoflama visualizes the current airborne particulate matter concentration from the nearest sensor.community measurement station, inspired by http://stoflamp.nl The data that the LED colour is based on is retrieved over WiFi from the sensor.community website every 5 minutes.
Features:
  • The lamp shows particulate matter concentration as a colour, from dark blue for low concentration to bright pink for high concentration
  • The lamp retrieves the PM value over wifi from the the sensor.community website, there is a one-time setup to configure your WiFi network so the device can access the internet
  • The lamp automatically determines the nearest sensor.community particulate measurement station, by doing WiFi-based geolocation.
  • The number/id of the sensor.community station can also be entered manually during the one-time setup.
  • Experimental branch retrieves particulate matter data from stofradar.nl, which is more responsive, also includes data from RIVM
Ideas/nice to have/todo:
  • Instead of controlling a light directly, send a command over infrared remote to an RGB lamp already having remote control, see https://www.instructables.com/Reverse-Engineering-RGB-LED-Bulb-with-IR-remote/
Simplified REST API
Problems with the current implementation:
  • communicaton with sensor.community fails randomly, or takes very long
  • the auto-detection method puts a burden on the sensor.community servers, takes very long
  • only returns data from sensor.community, not from other providers (like RIVM, samenmeten)
New plan:
  • Create my own API to get a PM-value
  • The API runs on my own server (www.stofradar.nl), where I have full control over performance, features, etc.
  • REST-like protocol, e.g. HTTP GET /v1/airquality/latitude>/<longitude>
  • Response is a JSON structure which contains an interpolated PM value:
    • field "PM2.5" contains the PM2.5 value in ug/m3
    • field "color" contains a color in RGB hex, according to luchtmeetnet colour scale
  • Implemented as a REST resource, based on the values aggregated in stofradar.nl
    • simple square geofilter around the requested geo location, say 25x25 km
    • inverse-distance squared weighted value from values with the square
  • Data sources are sensor.community and RIVM (samenmeten)
  • The API will be part of the stofradar application, which already collects the data from sensor.community and RIVM (samenmeten)
  • The lamp still performs its own geolocation (can cache it), then queries this API, so this remains a two-step process
Building it
stoflama
It consists of a few parts:
  • a Wemos D1 mini board
  • a LED shield, either the one with 1 LED, or the one with 7 LEDs (preferred, brighter)
  • a plastic lamp enclosure
Steps:
  • solder the female headers onto the Wemos D1 mini, start with soldering just one pin so you can re-heat it and adjust it if the fit with the male pins is not quite right.
  • connect the USB micro cable and flash the firmware into the Wemos d1 mini board
  • verify that it works as expected, on startup it does a quick colour animation, starting and ending with the red colour
Operation Manual
stoflama
Flashing the firmware
  • Connect everything up as indicated under 'hardware' and connect the Wemos D1 board to the USB port of your development PC / laptop
  • Flash the software into the Wemos D1 mini. Open a command line and enter the 'stofananas' source code directory, then compile and upload it using the following command:
 sudo apt install python-pip
 sudo pip install platformio
Configuration
configuration
Automatic configuration:
  • power up the lamp
  • when presented with the captive portal, select a WiFi network, fill in the WiFi password, leave the luftdaten id field EMPTY, press SAVE
  • the closest sensor.community particulate matter sensor will automatically be determined
Manual configuration:
  • power up the lamp
Alternatively:
  • make sure at least the WiFi credentials have been entered and saved
  • open a console to the serial port of the wemos D1 mini (115200 bps) and enter the following command:
 config auto
  • within a few seconds, you should see it prints the current approximate geographic location and the id of the sensor.community station, the id should be non-zero. It is saved in internal memory.
Usage
  • A flashing colour (1x per second) means that something went wrong, either communication with the sensor.community server or decoding the sensor.community server response
  • ArduinoJSON (v 6.19.4) for parsing the sensor.community response
  • FastLED (v 3.5.0) is used to control the RGB LED
  • WiFiManager (v 0.16.0) is used to manage WiFi connection to the local WiFi access point
Sensor.community interface
 http://data.sensor.community/airrohr/v1/sensor/<sensor-id>/
where <sensor-id> is the database id used by sensor.community (and visible on their map). The trailing slash in the URL is significant.
For example:
 http://data.sensor.community/airrohr/v1/sensor/12246/
Colour mapping
FastLED rainbow hue chart
Mapping is currently as follows:
  • 0 ug/m3: deep blue
  • 15 ug/m3: green
  • 30 ug/m3: yellow
  • 60 ug/m3: red
  • 120+ ug/m3: pink
Chapter 8.3 unfortunately still puts the final colour scale for an air quality index as a point under discussion:
 "Er is overeenstemming over het baseren van de index op dosis-respons
 relaties en het schalen van de componenten naar ordegrootte
 gezondheidseffecten. De analyse die heeft geleid tot een indeling in tien
 klassen is beschreven in hoofdstuk 6. Er is tevens de wens geuit, zowel
 door gebruikers als experts, om in de uiteindelijke presentatie te komen
 tot vier klassen met bijbehorende kleur, labels en handelingsperspectief.
 De precieze afkappunten daarvoor zijn arbitrair. Na de expertbijeenkomst,
 bijeenkomsten met gebruikers en twee commentaarronden onder de experts
 is nog geen consensus over de uiteindelijke indeling van de index in vier klassen.
 De onderstaande indeling (zie Tabel 11) doet zoveel mogelijk recht aan de adviezen van
 de experts en gebruikers, en biedt mogelijkheden om een consistent
 geheel te vormen met de smogregeling. Nog openstaande
 discussiepunten worden hier beschreven."
The https://www.luchtmeetnet.nl/ page uses the following range: https://www.luchtmeetnet.nl/informatie/luchtkwaliteit/luchtkwaliteitsindex-(lki)
Next generation
lamp-sensor pairing sequence diagram
The next generation uses the ESP-NOW protocol, supported by both the ESP8266 and ESP32 microcontrollers. ESP-NOW is a connection-less WiFi protocol running at a reduced rate of 1 Mbps, it does not require any credentials (like WEP/WPA) to be entered. The lamp is *not* connected to regular WiFi, this is different from (say) the mechanism used by the sensor.community flashing tool to find a sensor in the local network.
The idea is that you just put a ESP-now enabled light in the vicinity (several 10s of meters) of the particulate matter sensor and they will automatically discover each others' presence and start communicating measurement values.
Protocol
Pairing works as follows:
  • The lamp sends broadcast discovery messages (possibly on different channels) to announce its presence and discover the sensor, it flashes blue while doing so.
  • The dust sensor receives the broadcast discovery message and sends an associate message back.
  • The lamp receives the associate message, it stops flashing blue.
  • The (implicit) ACK from the lamp back to the sensor signals that the association is complete, the sensor remembers the lamp MAC and id
  • When a new measurement is done, the sensor sends a data message to the lamp. The lamp shows the associated color.
 {"msg":"data","PM10":12.3,"PM2.5":8.4,"PM1.0":4.5,"humidity":42.5,"temperature":14.3,"pressure":102511,"color":"#11FF00"}
 {"msg":"data","color":"#ffff00"}
The lamp software can be implemented to either just display the color, or calculate it from the measurement.
Source code is available here: https://github.com/bertrik/pmlamp-espnow-proto
Power on the lamp, the LED starts flashing blue, then power on the sensor, the LED stops flashing. You can connect over serial to the sensor node and type a command like 'led FF0000' to set the color of the lamp to red.
Other resources
