Stofradar
Revision as of 17:21, 22 December 2021 by Bertrik Sikken (talk | contribs)
Project Stofradar
Visualizing airborne particulate matter concentrations on a map
Last Update 2021-12-22
See also my DustSensor page.
Future activities:
  • Rename the luftdatenmapper project to stofradar, since luftdaten renamed themselves in the meantime.
  • put more measurements on the map: luchtclub Rotterdam has a lot of sensors, but doesn't share them with sensor.community!
  • plot official luchtmeetnet measurements on the map too, access to the API has been implemented work in progress
  • play with different algorithm:
    • for each pixel consider only stations with a certain radius (say 10 km), calculate the median, convert median to color
    • should more naturally filter out outliers and is actually a bit similar to what sensor.community uses.
  • add a water mark
Visualisation
Background map
Data filtering
There is only very minimal data filtering. Sensor measurements are taken into account as follows:
  • Sensors from an area 2x2 times bigger than the area visualized are considered for visualisation
  • Sensors marked as 'indoor' are ignored
  • Sensors with a measurement value smaller than 0 are ignored
  • The top percent of highest PM2.5 concentrations is discarded, this mostly takes care of outliers caused by defective sensors
  • When sensor data is not available in the past 5 minutes, data from a previous measurement interval is used, up to 1 hour old
  • A (small) number of sensors that are known to always report a very high value are not considered (blacklisted)
Interpolation
  • calculate the "km-per-degree-latitude" at the middle for latitude as 40075 km / 360 degrees;
Colour range
Luchtmeetnet ranges
Correction for high humidity
Humidity generally seems to cause an overestimation of PM measurements for measurements done with a "particle counting" type of PM sensor. The effect become really significant above approximately 70% humidity.
Animation
  • GIF animation composed of hourly images over the past 24 hours
  • WEBM animation composed of 5-minute images over the past 24 hours
You can click on the GIF animation to view the WEBM animation.
