Stofradar
| Project Stofradar | |
| Visualizing atmospheric particulate matter concentrations on a map | |
| Last Update | 2021-09-05 |
See also my DustSensor page.
Future activities:
- find a universally agreed-upon color scale, and add a legend
- investigate why sometimes an image cannot be calculated (API not accessible?)
- plot official luchtmeetnet measurements on the map too, access to the API has been implementedwork in progress
Visualisation
Background map
Interpolation
- calculate the "middle" of the map (average latitude/longitude between top-left and bottom-right);
- calculate the "km-per-degree-latitude" at the middle for latitude as 40075 km / 360 degrees;
- calculate the "km-per-degree-longitude" at the middle for longitude as the number above multiplied with cos(latitude);
- determine the difference in longitude and the difference in latitude;
- convert both to km using the factors calculated earlier;
- calculate the euclidean distance.
PM10 values < 0 ug/m3 are ignored in the software.
Colour range
Correction for high humidity
Humidity generally seems to cause an overestimation of PM measurements for measurements done with a "particle counting" type of PM sensor. The effect become really significant above approximately 70% humidity.
- https://www.samenmetenaanluchtkwaliteit.nl/sites/default/files/2018-07/Status_SDS011_12juli18.pdf
- https://www.researchgate.net/publication/320474792_Influence_of_Humidity_on_the_Accuracy_of_Low-Cost_Particulate_Matter_Sensors
- https://github.com/opendata-stuttgart/meta/wiki/Luftfeuchte-Korrektur
- it combines formulas and coefficients from different sources where relative humidity has different units. One paper seems to use an RH-value from 0 to 100, while another uses a kind of normalized relative humidity (from 0 to 1). You cannot just use the same coefficients if the unit is different.
- it claims a humidity correction for PM10 with coefficients that is not found in the source paper.
Animation
- GIF animation composed of hourly images over the past 24 hours
- WEBM animation composed of 5-minute images over the past 24 hours
You can click on the GIF animation to view the WEBM animation.
