Sensor-data-bridge
| Project LoraLuftdatenForwarder | |
| LoRaWAN forwarder for particulate matter data | |
| Last Update | 2021-04-12 |
What is this
It is a Java application that takes airborne particulate matter measurement data transferred through TheThingsNetwork and forwards it to http://sensor.community (formerly Luftdaten) and http://opensensemap.org .
Features
- Picks up particulate matter measurement data received through TheThingsNetwork, using their "v3" infrastructue
- Forwards measurement data to sensor.community
- Forwards measurement data to opensensemap.org, you can configure the opensense-id by adding a device attribute in TheThingsNetwork console
- Forwards measurement data to cayenne.mydevices.com, you configure the username/password/clientid by adding a device attribute in TheThingsNetwork console
- Supports Cayenne payload format for the data encoding
- Handles particulate matter data (PM10, PM4.0, PM2.5, PM1.0), temperature, humidity, barometric pressure
- Can be run as a systemd service, so it automatically restarts in case the software would crash
- add support for direct pushing to cayenne.mydevices.com API description at https://developers.mydevices.com/cayenne/docs/cayenne-mqtt-api/#cayenne-mqtt-api-overview-using-mqtt-with-cayenne-option-3-use-http-to-push-mqtt-data
- add support for NB-IOT modem with t-mobile backend, see my Sim7020 project
- add support for other backends, e.g. feinstaub-app?
Requirements
You need the following:
- a Java installation (JDK to compile), at least version 8
Compilation
To compile the software:
- enter the LoraLuftdatenForwarder/gradle directory
- run the gradle script to build the software:
./gradlew assemble
- the application zip & tar is now available in LoraLuftdatenForwarder/LoraLuftdatenForwarder/build/distributions
git pull
Installation
cd tar xvf code/LoraLuftdatenForwarder/LoraLuftdatenForwarder/build/distributions/LoraLuftdatenForwarder.tar
Configuration
Node configuration
- PM4.0 is encoded as analog value on channel 4 (optional)
- Within the application you need a 'device', so create a new one, or use an existing one:
- Use OTAA, LoRaMac version probably 1.0.3
- You need an API key
- Create this on the TTN console, grant individual rights as shown in the screenshot
LoraLuftdatenForwarder configuration
To configure the application:
cd LoraLuftdatenForwarder bin/LoraLuftdatenForwarder (ctrl-C)
- Edit the loraluftdatenforwarder.yaml file, example:
ttn:
identity_server_timeout: 20
apps:
- name: "particulatematter"
key: "NNSXS......."
encoding: "CAYENNE"
luftdaten:
timeout: 20
opensense:
timeout: 20
So:
Sensor.community
TODO
- Register a node with id 'TTN-<device-EUI-as-shown-on-display>' (without the spaces or hyphens, e.g. 'TTN-0000547AF1BF713C')
Opensensemap
- Go to opensensemap.org and log in
- Create an opensense node with the proper configuration
- Copy the opensensenmap 'box id', a long hexadecimal string
- Add an attribute for the device, under 'General settings', name = 'opensense-id', value = boxid that you copied from opensensemap.org
- The mapping from TTN-id to boxid is refreshed by the forwarder once an hour, so within an hour the forwarding to opensensemap.org starts
Work in progress
Forwarding noise data
- Three values are sent in the JSON to sensor.community:
- "noise_LAeq", value in dB(A), meaning?
- "noise_LA_min", value in dB(A), some kind of minimum
- "noise_LA_max", value in dB(A), some kind of maximum
I think these can be encoded in Cayenne as a simple analog value (which has a range of approximately -327..327 with a resolution of 0.01. Just need to assign a channel number to it.
- call to dnms_calculate_leq()
- call to dnms_read_data_ready(&data_ready) returns 0 if OK and (data_ready != 0)
- call to dnms_read_leq(&dnms_values) returns 0 if OK
- firmware applies a "correction" by adding a fixed offset
References:
- DNMS is read at https://github.com/opendata-stuttgart/sensors-software/blob/beta/airrohr-firmware/airrohr-firmware.ino#L3392
- DNMS is formatted in the JSON at https://github.com/opendata-stuttgart/sensors-software/blob/beta/airrohr-firmware/airrohr-firmware.ino#L3405
- DNMS I2C code is at https://github.com/opendata-stuttgart/sensors-software/blob/beta/airrohr-firmware/dnms_i2c.cpp
