TwinklingBar
Versie door 10.42.42.9 (overleg) op 1 okt 2011 om 23:26 (Created page with " On a stormy sunday night on #revspace, fenrir saw the [httphttp://www.leds-buy.nl/led-terrenhemel-42-leds-1629.html led starry sky] at leds-buy, and tought it would be neat to ...")
(wijz) ← Oudere versie | Huidige versie (wijz) | Nieuwere versie → (wijz)
On a stormy sunday night on #revspace, fenrir saw the [httphttp://www.leds-buy.nl/led-terrenhemel-42-leds-1629.html led starry sky] at leds-buy, and tought it would be neat to have this in the hxx/eth0 bar. Some discussion ensued, and it was decided: we will build one.
The basic gest of the design: some microcontroller to drive the whole-shebang, a bunch of PWM controllers to take input from the microcontroller and drive the leds and presto. Aiming for about 100 RGB leds.
| *Part* | *Pieces* | *Price* | *Besteld* | *Real price* | | [httphttp://nl.mouser.com/ProductDetail/Texas-Instruments/TLC5941NT/?qs=sGAEpiMZZMtEZf%252bBk5%2f8xwZiHP6816qs TLC5941 28pdip (pwm controller)] | 20 | 54.75 | 2010-01-31 | 65.70 | | [httphttp://www.leds-buy.nl/standaard-leds/full-color-leds/fading-full-color-led-90-graden-5mm-ca.html rgb led CA, 5mm 90 graden] | 100 | 98.77 | 2010-01-31 | 84.79 | | Arduino | 1 | 30.00 | | | | Flat-cables | 1 | 50.00 | 2010-01-31 | 12.68 | | connectors between controller boards [httphttp://nl.farnell.com/harting/09-18-506-7803/socket-idc-w-o-s-relief-6way/dp/1106769 female] + male headers | 40 | 80 | 2010-01-31 | 30.50 | | connectors between controller boards [httphttp://nl.farnell.com/harting/09-18-506-7803/socket-idc-w-o-s-relief-6way/dp/1106769 female] + male headers | 40 | 80 | 2010-01-31 | 8.25 | | arduino proto shield | 1 | 5.00 | | | | montagedraad | 1 rol | 10.00 | 2010-01-31 | 2.07 | | [httphttp://www1.conrad.nl/scripts/wgate/zcop_nl3/~flN0YXRlPTQzMDI0NzE2NQ==?~template=pcat_area_s_browse&perform_special_action=DirektContentTemplate&template=Z_STICHWORTVERZEICHNIS&p_page_to_display= printplaten] | 20 | 70.20 | | | | misc (resistors, transistors, ..) | x | 20.00 | | | | 4-aderige kabel | 1 rol | 40.00 | | | | hout + verf | 1 | 50.00 | | | | Total | | %CALC{"$SUM( $ABOVE() )"}% | | %CALC{"$SUM( $ABOVE() )"}% |
PWM controllers:
  • [httphttp://focus.ti.com/docs/prod/folders/print/tlc5940.html TLC5940] - pretty neat, individual control
  • [httphttp://nl.farnell.com/on-semiconductor/cat9532wi/led-driver-16bit-program-24soic/dp/1656134 CAT9532WI] - cheaper but less control
Some wild ideas:
  • make it sensitive and react to E/M or perhaps light/IR sensors
  • sensitive to sound
  • web-interface
Winkelwagentje HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Mouser-onderdeel # OF fabrikantonderdeel# Uw onderdeelnr. * Aantal
  • Uw onderdeelnr. is een optioneel veld.
Om deze bestelling op te slaan als een project, Aanmelden of een My Mouser-account aanmaken
Alles selecteren Dit winkelwagentje opslaan Dit winkelwagentje delen met een collega
Verwijderen Productdetail Klantonderdeelnr.
Besteld aantal
Prijs (EUR)
Toestel (EUR)
Mouser-nr. 517-929836-01-03-RK Fabrikantnr: 929836-01-03-RK Fabrikant: 3M Omschr.: Headers & Wire Housings 6P PIN STRIP HEADER STRAIGHT, TIN, 2ROW RoHS: RoHS-conformiteit
Een asterisk, '*', is geen geldig teken voor het klantonderdeelnummer. Niet-ondersteunde tekens: {0}
Beschikbaarheid 50 Wordt nu verzonden � 0,165 � 8,25
Mouser-nr. 517-3365/06-100 Fabrikantnr: 3365/06-100 Fabrikant: 3M Omschr.: Flat Cable .050 6C ROUND 28AWG GRAY STRANDED WIRE RoHS: RoHS-conformiteit
Beschikbaarheid 1 Wordt nu verzonden � 12,68 � 12,68
Mouser-nr. 595-TLC5941NT Fabrikantnr: TLC5941NT Fabrikant: Texas Instruments Omschr.: LED Drivers 16ch LED driver with DC 12bitG/S RoHS: RoHS-conformiteit
Beschikbaarheid 30 Wordt nu verzonden � 2,19 � 65,70
  • [%ATTACHURL%/pwm-double-duo.ps|pwm-double-duo.ps]: Iteration 4 of the pcb
