Stofradar
Project Stofradar
Visualizing atmospheric particulate matter concentrations on a map
Last Update 2020-12-31
How can you help
What would really help me:
  • help to create a nice black-and-white background map (png) with equirectangular projection of an area larger than just the netherlands (e.g. containing also Belgium, perhaps part of west Germany, Ruhr-area). I would need the *exact* lat/lon coordinates of the area.
This requires:
  • you know what equirectangular means
  • have some more actual concrete knowledge/experience with maps (more than just: "qgis?")
See also my DustSensor page.
The website sensor.community is an initiative to allow citizens to participate in measuring atmospheric particulate matter concentration using an inexpensive and easy to build sensor. They collect this data, calculate 5 minute and daily averages and publish it again as open data. The total number of sensors is > 6000 worldwide, most of them in Germany, Bulgaria, Belgium, Austria, Sweden. The Netherlands has about 100 sensors.
Future activities:
  • plot PM2.5 and apply humidity correction
  • plot official luchtmeetnet measurements on the map too, access to the API has been implemented:work in progress
  • re-add a blacklist so we can suppress known bad measurement stations
  • use an OSM background map
  • improve fine alignment between map and dust overlay
  • create a map of a larger area, including germany (it has a lot of data points)
  • review and update stats mentioned above (e.g. "100 sensors in netherlands")
  • verify that gzip compression is used on the sensor.community JSON download
Visualisation
Background map
Pages to investigate:
What I need/want is to be able to specify the 'bounding box' and use a equirectangular projection , so I can easily map a pixel back to a latitude/longitude.
Interpolation
  • calculate the "km-per-degree-latitude" at the middle for latitude as 40000 km / 360 degrees;
A better way would be to use the 'great-circle-distance' and possibly even account for the fact that the earth is not perfectly spherical, but I like to start simple and this makes the calculation a lot faster.
Pixels that are not within a certain distance of any sensor station (e.g. 25 km) are rendered as grayscale, to indicate a geographic limit of each sensor.
Only sensors within a reasonable range of the map are taken into account, currently this is an area of 9 times (3x3) the visible area.
PM10 values higher than 500 ug/m3 are simply ignored in the software.
Colour range
The colours I'm using (a kind of inverted spectral range from blue to red):
  • 0 ug/m3: fully transparent white (#FFFFFF)
  • 25 ug/m3: semi-transparent cyan (#00FFFF)
  • 50 ug/m3: semi-transparent yellow (#FFFF00). This is the threshold for the maximum daily average for PM10 in the Netherlands.
  • 100 ug/m3: semi-transparent red (#FF0000)
  • 200 ug/m3 and higher: semi-transparent purple (#FF00FF)
This scale is approximately logarithmic, with each step being twice as big as the previous one.
Correction for high humidity
Humidity generally seems to cause an overestimation of PM measurements for measurements done with a "particle counting" type of PM sensor. The effect become really significant above approximately 70% humidity.
Compositing
I use imagemagick for this, for example:
 composite -compose over -geometry 600x800 20180605_210100.json.png netherlands.png output.png
where netherlands.png is an 600x800 opaque black-and-white image of the map of the netherlands and 20180605_210100.json.png is an 60x80 image of dust concentrations with an alpha channel
Animation
The idea of animation is to combine several 5-minute images into a movie.
There are several options and file formats to choose from:
  • GIF appears way too big, resulting in files of about 40 MB for 288 frames.
  • APNG is only slighty smaller at about 37 MB.
  • the webm format seems more suited, can be less than 1MB (lossy, VP9).
Example conversion command for webm:
 cat ~/luftdatenmapper/tmp/netherlands/*.png |ffmpeg -f image2pipe -r 12 -i - -b:v 200k netherlands.webm
This results in an output file of about 650 kB.
