MCP23017
| Project MCP23017 | |
| Guide: Connecting MCP23017 to ESP8266 | |
| Contact | sttc |
| Last Update | 2020-02-15 |
Status as of 2020/1/13:
- Completed
MCP23017 is a GPIO expander runs on I2C. This page forms wiring and communication guide for MCP23017 on ESP8266.
Used components:
- MCP23017
MCP23017 I2C Interface 16bit I/O Extension Module Pin Board IIC to GIPO Converter https://www.aliexpress.com/item/32883688022.html?spm=a2g0s.9042311.0.0.5d3e4c4d6bMkco
- ESP8266:
LiLon NodeMCU V3 4MB flash ESP8266 12E More info on ESP8266: https://randomnerdtutorials.com/esp8266-pinout-reference-gpios/
Wiring
Setting up ESP8266 for I2C pins is not necessary in this code. SCL and SDA pins as below:
| Pin on MCP23017 | ESP8266 |
| GND | GND |
| VCC | 3V |
| SCL | D1 (GPIO5) |
| SDA | D2 (GPIO4) |
Code
// MCP23017 Example: Slow key press reaction.
// Toggle LEDs and detect keypress.
// Example code showing slow reaction of 'button'
// LED to keypress. Leading into why interrupts
// are useful (See next example).
// Copyright : John Main
// Free for non commercial use.
#include <Wire.h>
#include <Adafruit_MCP23017.h>
#define MCP_LED1 7
#define MCP_INPUTPIN 8
#define MCP_LEDTOG1 11
Adafruit_MCP23017 mcp;
void setup() {
mcp.begin(); // Default device address 0
mcp.pinMode(MCP_LEDTOG1, OUTPUT); // LED for blinking
mcp.pinMode(MCP_LED1, OUTPUT); // LED output for button
mcp.digitalWrite(MCP_LED1, HIGH); // default > LED turn on
mcp.pinMode(MCP_INPUTPIN,INPUT); // Button i/p to GND
mcp.pullUp(MCP_INPUTPIN,HIGH); // Puled high to ~100k
void loop() {
// blinking led
delay(300);
mcp.digitalWrite(MCP_LEDTOG1, HIGH);
delay(300);
mcp.digitalWrite(MCP_LEDTOG1, LOW);
// Transfer input pin state to LED1
if (mcp.digitalRead(MCP_INPUTPIN)) {
mcp.digitalWrite(MCP_LED1,HIGH);
} else {
mcp.digitalWrite(MCP_LED1,LOW);
MCP21017 GPIO
Number in IDE =
mcp.pinMode(Number in IDE, OUTPUT);
| MCP21017 | Number in IDE |
| PA0 | 0 |
| PA1 | 1 |
| PA2 | 2 |
| PA3 | 3 |
| PA4 | 4 |
| PA5 | 5 |
| PA6 | 6 |
| PA7 | 7 |
| PB0 | 8 |
| PB1 | 9 |
| PB2 | 10 |
| PB3 | 11 |
| PB4 | 12 |
| PB5 | 13 |
| PB6 | 14 |
| PB7 | 15 |
Remarks
Pins of VCC,GND,SCL,SDA,RT,ITA,ITB line do not fit to the board together with GPIO pins (PA7, PA6...) > (Do not solder VCC... line pins)
