LED skirt
Revision as of 16:42, 13 January 2020 by Noor (talk | contribs)
Project LED-skirt
Contact Noor
Last Update 2020-01-13
To do
  • Add another Arduino microcontroller for LED strips only.
  • Battery holders.
  • Apply waterproofing lacquer on circles and panel.
  • Diameter of crinoline bottom hoop is 80 cm. Add an extra 100+cm of arc length of black paneling and tulle paneling to inner layers.
  • Replace strip in bottom tube with side-emitting LEDs?
LED count
  • 240 - circles (all used except one)
  • 64 - 8x8 panel.
  • 23 - strip 1.
  • 23 - strip 2.
  • 17 - strip 3.
  • 84 (?) - strip along bottom tube.
Total: 451 LEDs.
Timeline
2019-11-06 - 2019-11-11
Bought:
Old sketches:
2019-11-04 224115 - design1.png 2019-11-04 224123 - led skirt 2.png 2019-11-04 224131 - led skirt 3.png 2019-11-05 215433 - DSC06381.jpg 2019-11-05 215437 - DSC06382.jpg
2019-11-12 - 2019-11-24
  • Layout of LEDs, waiting for items to arrive.
  • Tested out LEDs under layers and on crinoline.
2019-11-23 220454 - DSC06537.jpg 2019-11-23 221724 - DSC06542.jpg 2019-11-24 173747 - DSC06546.jpg
2019-11-25
  • Took apart seams of inner layers of black skirt to add extra panels to fit over crinoline.
2019-11-26
  • Measured skirt on top of crinoline. Extra panel with bottom arc length of 100+cm.
  • Decided to go with 6 strips of 23 LEDs each. Cut one strip.
2019-12-03 - 2019-12-05
  • Tested out LED rings. One wire was detached so had to be soldered on.
2019-12-06
  • Punched holes in crinoline, used zip ties to attach first LED strip.
  • Took apart LED circles and tested FastLED programs.
  • Set up LED circles, one strip, and panel together on crinoline and used zip ties to place everything but the panel on crinoline.
  • Ran FastLED programs on everything together.
  • Pictures posted by others to Facebook, RevSpace kiekjes, Twitter.
2019-12-06 193923 - DSC06635.jpg 2019-12-06 194452 - DSC06637.jpg 2019-12-06 200017 - DSC06639.jpg 2019-12-06 220618 - DSC06666.jpg 2019-12-06 220632 - DSC06667.jpg 2019-12-06 220710 - DSC06668.jpg
2019-12-20
  • Rearranged LED circles, mounted some back on with velcro. Mounted panel with velcro.
  • Cut two more strips. Attached wires to one and mounted it horizontally at an angle.
2019-12-22
  • Folded up bottom hem and put velcro strips all across to partially make a tube along bottom.
2019-12-24
2019-12-25
  • Measured and cut panel for black layer of skirt.
2020-01-10
  • Used fabric glue along bottom hem tube, in between velcro strips.
  • Soldered wires to more LED strips.
2020-01-10 145148 - DSC08359.jpg 2020-01-10 165310 - DSC08360.jpg 2020-01-10 201701 - DSC08367.jpg 2020-01-10 205118 - DSC08368.jpg 2020-01-10 211717 - DSC08370.jpg 2020-01-10 213030 - DSC08371.jpg 2020-01-10 223034 - DSC08375.jpg 2020-01-10 225615 - DSC08377.jpg
2020-01-11
  • Soldered wires to remaining LED strips.
  • Connected everything together, hooked up to an Arduino.
2020-01-11 185141 - DSC08388.jpg 2020-01-11 191121 - DSC08389.jpg 2020-01-11 202121 - DSC08392.jpg 2020-01-11 202125 - DSC08393.jpg 2020-01-11 202717 - DSC08394.jpg 2020-01-11 203657 - DSC08396.jpg 2020-01-11 204945 - DSC08397.jpg 2020-01-11 210350 - DSC08401.jpg
