LichtKrant
| Project LichtKrant | |
| Controller for 3-colour 80x7 pixel moving LED sign | |
| Last Update | 2020-01-12 |
Hacked it, so now we have the following:
- reverse engineered the electronics and documented how it works
- replaced the controller board with an ESP8266, so we can receive image/text updates over the network
- implemented more colour depth, so we can display gradient bitmaps (not just red/green/orange but any color in between)
- wrote software for this and published it
Next:
pixelflut server, as described here, just skip the blue channelpixelflut is a shitty protocol, let's skip that- write a process for the revspace led banner that forwards all frames in a non-blocking manner to the TCP server built into the esp-ledsign.
help wanted =
You could help with the following:
- fix the package management system on the ledbanner pi
- write a TCP forwarder for led banner image data
- help with mounting this thing somewhere in the space
Reverse engineering
Processor board
It takes 5V as input.
LED board
How does it work
* J1.1: IC2.A1 -> IC2.B1 -> via ... -> shift clock
* J1.2: GND
* J1.3: IC2.A2 -> IC2.B2 -> via ... -> latch clock
* IC1.B2 -> IC1.A2 -> U11.RCLK
* IC1.B5 -> IC1.A5 -> U1.RCLK
* J1.4: GND
* J1.5: IC1.B3 -> IC1.A3 -> U11.SER -> data pin for upper shift register (green)
* J1.6: GND
* J1.7: IC1.B4 -> IC1.A4 -> U1.SER -> data pin for lower shift register (red)
* J1.8: GND
* J1.9: IC2.A7 -> IC2.B7 -> via ... -> row enable
IC4.1A -> IC4.1Y -> IC3.G2B
* J1.10: VCC
* J1.12: VCC
* J1.14: VCC
* J1.16: J4 (IR receiver)
* J1.17: IC2.A6 -> IC2.B6 -> IC3.G2A -> frame enable, appears to have a pull-up already, so can be left unconnected
* J1.18: ???
* J1.19: ???
- columns
- rows
- other
- 5V signals
- GND signals
Levels on the bus are 5V.
Theory of operation:
- next row
Timing
Columns:
Power consumption
The duty cycle of the LEDs is strongly determined by the row enable pins. It appears that J1.17 is used by the original control board to set the global brightness.
- all LEDs off, about 20 mA
- all red LEDs on, about 4.0 A
- all green LEDs on, about 3.7 A
- all LEDs (red + green) on, about 6.4 A
Hardware modifications
- soldered a power connector on the center of the display PCB, on the footprint that was already present, 5V is supplied there (up to 6 Amps!)
- removed the controller board
- added a Wemos D1 mini board, pinout:
| J1 connector | Wemos D1 mini | Remark |
| J1.1 | D8 | Column data shift |
| J1.3 | D7 | Column data latch |
| J1.5 | D6 | Green data |
| J1.7 | D5 | Red data |
| J1.8 | G | Ground |
| J1.9 | D4 | Row enable |
| J1.10 | 5V | 5V from LED board to Wemos D1 mini |
| J1.11 | D3 | Row select bit 0 |
| J1.13 | D2 | Row select bit 1 |
| J1.15 | D1 | Row select bit 2 |
sudo apt install python3-pip sudo pip3 install platformio
Driving the pixels
Variable pixel brightness
Variable pixel is implemented using a kind of duty-cycle/dithering modulation that flashes the pixels on/off:
- At each frame start, for each pixel, we add the brightness value from the frame buffer to the brightness count (e.g. 0-255). If the addition results in an overflow, the pixel is lit on the display, otherwise it is dimmed. For example, adding a brightness value of 128 causes the addition to overflow every other time, causing a 50%/50% duty cycle at half the update frequency.
- The above is implemented for the red and green pixels separately.
RAW RGB interface
RAW RGB frames (80x8x3 bytes) can be sent over TCP to port 1234. The blue (B) channel is ignored, as is the lowest line of the 80x8 raw RGB frame.
convert -size 80x10 -crop 80x8+0+2 -font 8-BIT\ WONDER.TTF -pointsize 9 -fill red -background black caption:"AweSome" -depth 8 rgb:- |netcat esp-ledsign.local 1234
convert metaballs.gif rgb:- |netcat -q0 esp-ledsign.local 1234
Command interpreter
Integration into revspace infrastructure
This display could be used as a kind of mirror of the main LED banner, except with no blue color component and 80x7 LEDs instead of 80x8. For example, we could put it up at the kitchen and get notified of people opening doors, doorbell, etc.
Problems:
- the ledbanner needs a way to access the esp-ledsign by name, e.g. using esp-ledsign.local, this could be done using avahi -> the ledbanner repository setup is messed up (try 'dnf install avahi-deamon' for example, no longer works)
- a way needs to be written that taps the graphics from the ledbanner and forwards it to the esp-ledsign
One solution is to write a little program:
- takes one full frame from stdin
- outputs that same frame to stdout
- duplicates the frame to a TCP connection to esp-ledsign.local over port 1234
- put this into the chain of applications processing ledbanner data on the ledbanner pi.
- essential is that it forwards the full frame and does not block doing this when the led sign is non-responsive / has a connect error / etc.
Possibly useful other info:
- https://medium.com/@tharindu_peiris/p10-led-display-panel-using-esp8266-wemos-d1-mini-nodemcu-1e463ad60722
- some fonts for rendering text on 7-pixel high https://damieng.com/blog/2011/02/20/typography-in-8-bits-system-fonts
- atari font, almost entirely 7-pixels high https://www.bigmessowires.com/atarifont.png
