LichtKrant
Project LichtKrant
350px
Some 3-colour 80x7 pixel moving LED sign
Status Initializing
Last Update 2019-12-16
Found this moving LED sign on the revspace free stuff table.
It is 80 pixels wide, 7 pixels high. Each pixel has two sub-pixels (red and green), so it can display 3 colours (off, red, orange, green)
Goals:
  • reverse engineer the electronics and document how it works
  • replace the controller board with an ESP32, so we can receive image/text updates over the network
  • implement more colour depth, so we can display gradient bitmaps (not just red, green, orange)
  • write software for this, so other people can do the same for their display
lichtkrantconnector
Processor board
It takes 5V as input.
LED board
The are already electronics on it, consisting mostly of 595 chips (serial shift registers). The are two chains of 10 pieces of 74hc595 chips each, controlling the columns.
There is an '138 chip (3-to-8 decoder) that drives a set of MOSFETS, 7 in total, controlling the rows.
The MOSFETs are SDM4953, dual P-channel MOSFETs.
Reverse engineering the LED board electronics
This is done by tracing out the connections from connector J1, which connects the processor board to the LED board.
*  J1: pin IC5.A8 -> IC2.A1 -> IC2.B1 -> via ... -> shift clock
*  J2: GND?
*  J3: pin IC6.A1 -> IC2.A2 -> IC2.B2 -> via ... -> latch clock
*                    IC1.B2 -> IC1.A2 -> U11.RCLK
*                    IC1.B5 -> IC1.A5 -> U1.RCLK
*  J4: GND?
*  J5: pin IC6.A2 -> IC1.B3 -> IC1.A3 -> U11.SER -> data pin for upper shift register
*  J6: GND?
*  J7: pin IC6.A3 -> IC1.B4 -> IC1.A4 -> U1.SER -> data pin for lower shift register
*  J8: GND?
*  J9: pin IC6.A4 -> IC2.A7 -> IC2.B7 -> via ... -> row enable
                  -> IC4.1A -> IC4.1Y -> IC3.G2B
* J10: VCC?
* J11: pin IC6.A5 -> IC2.A3 (row) -> IC3.A -> row select
* J12: VCC?
* J13: pin IC6.A6 -> IC2.A4 (row) -> IC3.B -> row select
* J14: VCC?
* J15: pin IC6.A7 -> IC2.A5 (row) -> IC3.C -> row select
* J16: ???
* J17: pin IC6.A8 -> IC2.A6 -> IC2.B6 -> IC3.G2A -> row enable?
* J18: ???
* J19: ???
* J20: connected to the "ethernet" dipswitch
IC2.A7 <- IC4.1A <- via
  • IC5 = 74HC245 (octal buffer) on CPU board
  • IC6 = 74HC245 (octal buffer) on CPU board
  • rows
    • 3-bits row select
  • columns
    • 1 bit shift clock shared for both shift registers
    • 1 bit latch clock shared for both shift registers
    • 1 data bit for 80-bit shift register 1
    • 1 data bit for 80-bit shift register 2
    • 2 row-enable bit signals, not completely figured out yet
  • other
    • 5V signals
    • GND signals
Levels on the bus are 5V.
The plan is to drive the display using an ESP32, with one core dedicated to the display and the other free to do other stuff (e.g. receiving messages over the network).
Brightness is done using a kind of PWM:
  • For each frame we add to it the brightness value from the frame buffer (e.g. 0-256). If the addition results in an overflow, the pixel is lit on the display. If no overflow occurs, the pixel is dimmed on the display.
  • Each pixel on the display starts with a random count, so we avoid synchronised flashing of the pixels on the display. In other words, pixels with the same brightness has the same duty cycle, but have random turn-of/turn-off times with respect to each other.
Communication between the cores consists purely of the state of the frame buffer. The main core writes the frame buffer, the real-time core reads the frame buffer.
Possibly useful other info:
