StofAnanas
Project StofAnanas | |
Showing particulate matter concentration as a coloured light | |
Status | Initializing |
Contact | bertrik |
Last Update | 2019-06-16 |
The idea
Show current airborne particulate matter concentration using a LED light in a lamp, inspired by http://stoflamp.nl The data that the LED colour is based on is simply retrieved over WiFi from the luftdaten website.
This lamp is a plastic pine apple ("ananas"), bought at the "Action" store.
Concepts/ideas:
- The lamp shows particulate matter concentration as a colour, e.g. soft/positive colours for low concentration and hard/bright colour for high concentration
- The lamp "breathes" by varying the intensity over time, e.g. a cycle of 10 seconds where the light dims a bit and brightens a bit. Perhaps we can increase the breathing rate as well for higher PM.
- The lamp retrieves the PM value over wifi from the the luftdaten website
Nice to have:
- Automatic determination of location by means of wifi location
- Remote control over IR
Operation Manual
Programming
- connect everything up as indicated under 'hardware' and plug the Wemos D1 in the USB port
- flash the software into the Wemos D1 mini, typically from the command line
Configuration
- on https://netherlands.maps.luftdaten.info find the particulate matter station you want to follow and note the number of the station, for example "12246"
- on a mobile phone, connect to the "ESP-STOFANANAS" network, and select login
- when presented with the captive portal, select a WiFi network, fill in the WiFi password, AND ALSO fill in the number you looked up earlier, press SAVE
- NOTE: when the configuration is ongoing, the LED will be YELLOW, it turns OFF when configuration is done.
The lamp is controlled by an ESP8266, a Wemos D1 mini board. The LEDs used has a built-in PL9823 controller.
Connections:
- LED Din to Wemos D1 mini pin D4
- LED Gnd to Wemos D1 mini pin GND
- LED Vdd to Wemos D1 mini pin 5V
Software is available on github.
Luftdaten interface
The current measurement value of a particular sensor can be retrieved over a REST interface, using URL
For example:
Arduino libraries
Libraries:
- WiFiManager is used to manage WiFi connection to the local AP
- FastLED is used to control the LED
- ArduinoJSON for the parsing the luftdaten response
