Luteijn/IRRemotes
< Luteijn
Project "IRRemotes":
| Project Luteijn/IRRemotes | |
| Bestand:I.R. Baboon 301-1-.png | |
| Contact | Luteijn |
| Last Update | 2018-02-04 |
Controlling things with an IR Remote is fun. Here's what some of my remotes send out, for easy (re)use in projects with an IR Receiver. Sniffed the codes with a Vortex robot, made up the names in the tables myself.
RC6 'windows' remote
This sends 36-bit RC6 codes. They all seem to be of the form 0xC8034x4hl. The leading C doesn't show with my current decoder of choice, or isn't really there. The x is either 8 or 0, flipping for each key pressed, so you can distinguish between a key being held or pushed twice in a row. The h and l indicate the variable bits in the code sent, the tables below give a name to each of these.
For this first table, the order is a left to right, top to bottom scan of the remote, treating the volume and channel + - as one, rocker, button.
| Code | Label | Code | Label | Code | Label | Code | Label | Code | Label | Code | Label | |||||
| 0C | power | 30 | pause | 37 | record | 31 | stop | 29 | reverse | 2C | play | |||||
| 28 | forwards | 21 | previous | 20 | next | 83 | back | CB | info | 58 | up | |||||
| 5A | left | 5C | ok | 5B | right | 59 | down | 10 | vol+ | 11 | vol- | |||||
| 5D | logo | 1E | ch+ | 1F | ch- | 0D | mute | 9B | tvrecord | 3E | tvguide | |||||
| 2E | tvplay | 54 | disc | 01 | 1 | 02 | 2 | 03 | 3 | 04 | 4 | |||||
| 05 | 5 | 06 | 6 | 07 | 7 | 08 | 8 | 09 | 9 | 33 | * | |||||
| 00 | 0 | 32 | # | 3A | clear | 2F | teletext | 34 | enter | 6D | red | |||||
| 6E | green | 6F | yellow | 70 | blue |
The next table is sorted by in the code order:
| 00 | 0 | 01 | 1 | 02 | 2 | 03 | 3 | 04 | 4 | 05 | 5 | |||||
| 06 | 6 | 07 | 7 | 08 | 8 | 09 | 9 | 0C | power | 0D | mute | |||||
| 10 | vol+ | 11 | vol- | 1E | ch+ | 1F | ch- | 20 | next | 21 | previous | |||||
| 28 | forwards | 29 | reverse | 2C | play | 2E | tvplay | 2F | teletext | 30 | pause | |||||
| 31 | stop | 32 | # | 33 | * | 34 | enter | 37 | record | 3A | clear | |||||
| 3E | tvguide | 54 | disc | 58 | up | 59 | down | 5A | left | 5B | right | |||||
| 5C | ok | 5D | logo | 6D | red | 6E | green | 6F | yellow | 70 | blue | |||||
| 83 | back | 9B | tvrecord | CB | info |
RTeL-Cheapo remote
This El-Cheapo remote came with one of my RTL-dongles. Decodes as an NEC-code, sending a '32-bit' code when a key is pressed, followed by a 0-bit code as long as the key is held. Only the lowest 16 bits seem to change. The keypad is a 3x67 matrix
| FFB24D | power | FF2AD5 | source | FF6897 | mute | ||
| FF32CD | record | FFA05F | ch+ | FF30CF | time shift | ||
| FF50AF | vol- | FF02FD | full screen | FF7887 | vol+ | ||
| FF48B7 | 0 | FF40BF | ch- | FF38C7 | recall | ||
| FF906F | 1 | FFB847 | 2 | FFF807 | 3 | ||
| FFB04F | 4 | FF9867 | 5 | FFD827 | 6 | ||
| FF8877 | 7 | FFA857 | 8 | FFE817 | 9 |
Shinco RC-1606
This remote came with our Chinese DVD player many of the key labels are in Chinese. Decodes as an NEC-code, and like the RTeL-Cheapo remote it will send a '32-bit' code when a key is first pressed, and then a 0-bit code as long as it is held. Only the lowest 16 bits seem to change. The basic layout is 4 buttons per row, but the central bit is 3 rows of 3 slightly larger buttons.
| 99728D | screen display | 9938C7 | power | |||||||
| 996A95 | subtitles | 99CA35 | language | 9918E7 | channel | 992AD5 | point of | |||
| 99807F | repeat | 99D02F | pause | 9900FF | play mode | 9942BD | progressive/interlaced | |||
| 99B24D | set | 99E01F | title | 9930CF | menu | 9950AF | return | |||
| 997887 | previous | 993AC5 | up | 99DA25 | next | |||||
| 997A85 | left | 9928D7 | play | 99FA05 | right | |||||
| 99708F | reverse | 99BA45 | down | 9968A7 | forward | |||||
| 99F00F | stop | 99C837 | pause | 99EA15 | step | 99A05F | time search | |||
| 99906F | 1 | 99B847 | 2 | 99F807 | 3 | 99F20D | +5 | |||
| 99B04F | 4 | 999867 | 5 | 9948B7 | 0 | 99609F | mute | |||
| 9902FD | standard | 9940BF | bookmark | 99E21D | V- | 9912ED | V+ |
Xtreamer
This remote came with my 'Xtreamer'; many of the keys have more than one label, as they are used differently depending on context. Decodes as an NEC-code, and like the RTeL-Cheapo remote it will send a '32-bit' code when a key is first pressed, and then a 0-bit code as long as it is held. Only the lowest 16 bits seem to change. The basic layout is 3 buttons per row.
| FF20DF | power | FFDA25 | home | ||||
| FFA25D | 1 / add / red | FFE817 | 1 / eject / green | FF48B7 | 3 / delete / yellow | ||
| FFF20D | 4 / zoom | FFC03F | 5 / goto / blue | FF906F | 6 / menu | ||
| FF38C7 | 7 / setup | FF4CB3 | 8 / func | FF9867 | 9 / tvout | ||
| FF5AA5 | info | FF8C73 | 0 / preview | FF50AF | return | ||
| FF728D | up | ||||||
| FF30CF | left | FF609F | enter | FFA05F | right | ||
| FFB24D | down | ||||||
| FF1AE5 | previous / pgup | FF0AF5 | next / pgdn | ||||
| FF32CD | pause/play | FF7887 | stop | ||||
| FF3AC5 | reverse | FFD22D | forwards | FF18E7 | vol+ | ||
| FF708F | audio | FF00FF | A-B | FF827D | vol- | ||
| FFCC33 | shuffle | FF08F7 | repeat | FF58A7 | mute | ||
| FFF00F | subtitle | FF807F | sync subtitle << | FF12ED | sync subtitle >> |
Amoi RC305T
This remote came with my 37 inch LCD tv; some of the keys have more than one label, as they are used differently depending on context. Decodes as an NEC-code, and like the RTeL-Cheapo remote it will send a '32-bit' code when a key is first pressed, and then a 0-bit code as long as it is held. Only the lowest 16 bits seem to change. The basic layout is 4 buttons per row. Some of the number keys are not responding well anymore, graphite pads seem to bee depleted. with the remote opened, they could be activated, and it was also clear there is an extra row of keys that have no external buttons connected to them. controlelr chip of the remote is a PT2222, datasheet at http://www.datasheetcatalog.com/datasheets_pdf/P/T/2/2/PT2222-001.shtml tells us this is pin-to-pin compatible with NEC μPD6122.
| 40BD02FD | power | |||||||||
| 40BD708F | source | 40BD728D | sub source | 40BDF20D | last source | 40BD827D | mute | |||
| 40BDC23D | freeze | 40BD8A75 | aspect | 40BD629D | sleep | 40BD50AF | display | |||
| 40BD6A95 | video off | 40BDAA55 | swap | 40BD926D | pip/pbp | 40BD2AD5 | pop | |||
| 40BD42BD | picture | 40BDE21D | sound | 40BDEA15 | headphone - | 40BD1AE5 | headphone + | |||
| 40BD807F | 1 / symbol | 40BD40BF | 2 / abc | 40BDC03F | 3 / def | 40BDD02F | dual | |||
| 40BD20DF | 4 / ghi | 40BDA05F | 5 / jkl | 40BD609F | 6 / mno | 40BDB04F | swap | |||
| 40BDE01F | 7 / pqrs | 40BD10EF | 8 / tuv | 40BD906F | 9 / wxyz | 40BD00FF | 0 / space | |||
| 40BDE817 | volume + | 40BD30CF | list | 40BD22DD | page >> | 40BD6897 | ch + | |||
| 40BDA857 | volume - | 40BD28D7 | menu | 40BDA25D | page << | 40BD18E7 | ch - | |||
| 40BDC837 | up / teletext next subpage | |||||||||
| 40BD08F7 | left | 40BD9867 | ok / teletext info | 40BD48B7 | right | |||||
| 40BD8877 | down / teletext previous subpage | |||||||||
| 40BD12ED | play / pause / teletext x | 40BDB24D | stop / teletext zoom upper | 40BD52AD | digest / teletext zoom lower | 40BDF00F | exit | |||
| 40BD9A65 | zoom / teletext no zoom | 40BDD22D | rotate / teletext hold | 40BD32CD | function / teletext reveal | 40BD0AF5 | txt / mix / teletext | |||
| 40BD4AB5 | red | 40BDCA35 | green | 40BD5AA5 | yellow | 40BDDA25 | blue | |||
| 40BD3AC5 | no button 1 | 40BDBA45 | no button 2 | 40BD7A85 | no button 3 | 40BDFA05 | no button 4 |
Onkyo RC-342M
This remote came with an Onkyo Receiver. Has a switch to switch (some) of the keys to a sub-room setting, and ten programmable keys to try to help to reduce remote-clutter. This also decodes as NEC, and sends a 32-bit code for the first press, and then 0-bit codes to signal the same key is still down. As usual only the lower 4 bits seem to be variable.
| 4BB620DF | power | 4BB6BA45 | sleep | 4BB6A956 | dimmer | 4BB69A65 | main | 4BB65AA5 | remote | ||||
| 4BB6F00F | video-1 | 4BB6708F | video-2 | 4BB6B04F | video-3 | 4BB6F906 | video-4 | 4B3620DF | multi-ch input |
CL-200T
This remote came with our motorized curtain rails. This decodes as 'unknown'. it has 8 'channel' buttons, that only send a code once, even if held down. Seems to be a kind of 'attention, next messages are for you'-function, as the actual codes sent by the 'action' button don't seem to vary. There is an open, close and a pair of stop buttons. The stop buttons spam the same command when held, as a kind of panic mode :).
Code seems 12 bits of code, e.g.:
Raw (24): 400 -1250 400 -1250 400 -1300 1200 -450 400 -1250 450 -1250 1200 -450 400 -1300 400 -1250 400 -1250 400 -1300 400
____-___-___-___---_-___-___---_-___-___-___-___-____
0 0 0 1 0 0 1 0 0 0 0 0
Raw (24): 400 -1250 450 -1250 400 -1250 1250 -400 450 -1250 400 -1250 400 -1250 1250 -450 400 -1250 450 -1250 400 -1250 400
____-___-___-___---_-___-___-___---_-___-___-___-____
0 0 0 1 0 0 0 1 0 0 0 0
Raw (24): 400 -1250 400 -1300 400 -1250 400 -1250 1250 -450 400 -1250 1250 -400 450 -1250 400 -1250 400 -1250 450 -1250 400
____-___-___-___-___---_-___---_-___-___-___-___-____
0 0 0 0 1 0 1 0 0 0 0 0
Some of this could be lead in and lead out...
