Luteijn/IRRemotes
Project "IRRemotes":
| Project Luteijn/IRRemotes | |
| Contact | Luteijn |
| Last Update | 2018-02-03 |
IRRemotes
Controlling things with an IR Remote is fun. Here's what some of my remotes send out, for easy (re)use in projects with an IR Receiver. Sniffed the codes with a Vortex robot, made up the names in the tables myself.
RC6 'windows' remote
This sends 36-bit RC6 codes. They all seem to be of the form 0xC8034x4hl. The leading C doesn't show with my current decoder of choice, or isn't really there. The x is either 8 or 0, flipping for each key pressed, so you can distinguish between a key being held or pushed twice in a row. The h and l indicate the variable bits in the code sent, the table below gives a name to each of these. Order is a left to right, top to bottom scan of the remote, treating the volume and channel + - as one, rocker, button.
| Code | Label |
| 0C | power |
| 30 | pause |
| 37 | record |
| 31 | stop |
| 29 | reverse |
| 2C | play |
| 28 | forwards |
| 21 | previous |
| 20 | next |
| 83 | back |
| CB | info |
| 58 | up |
| 5A | left |
| 5C | ok |
| 5B | right |
| 28 | down |
| 10 | vol+ |
| 11 | vol- |
| 5D | logo |
| 1E | ch+ |
| 1F | ch- |
| 0D | mute |
| 9B | tvrecord |
| 3E | tvguide |
| 2E | tvplay |
| 54 | disc |
| 01 | 1 |
| 02 | 2 |
| 03 | 3 |
| 04 | 4 |
| 05 | 5 |
| 06 | 6 |
| 07 | 7 |
| 08 | 8 |
| 09 | 9 |
| 33 | * |
| 00 | 0 |
| 32 | # |
| 3A | clear |
| 2F | teletext |
| 34 | enter |
| 6D | red |
| 6E | green |
| 6F | yellow |
| 70 | blue |
RTeL-Cheapo remote
This El-Cheapo remote came with one of my RTL-dongles. Decodes as an NEC-code, sending a 32-bit code when a key is pressed, followed by a 0-bit code as long as the key is held.
| Code | Label |
| FFB24D | Power |
