CO2MeterHacking
| Project CO2MeterHacking | |
| Last Update | 2017-03-18 |
status: it works. We're working on modifying the code to work to also work on an ESP8266 which publishes the measurement data directly on an MQTT stream.
We found out that the G, C, D, V signals are routed internally to the RJ45-plug (but we didn't document which signal goes to which pin ...), so there's actually no need to open the CO-100 and solder a connector on the G, C, D, V lines.
This project is about hacking the Voltcraft CO-100 CO2-sensor, such that we can read the exact ppm value as displayed on the LCD.
This particular CO2-sensor is present in the klusbunker at RevSpace and is currently used to control the ventilation in a crude manner (by monitoring the warning LEDs on the display module). Having the CO2 ppm value available as a number allows for nice things such as logging the levels over time, announce them on IRC, show them on the LedBanner , etc.
The user manual of the Voltcraft CO-100 says "Achtung! Der RJ45-Anschluss (siehe Kapitel 7, Position „K“) darf nicht verwendet werden. Der Anschluss ist nur für den Hersteller vorgesehen." Of course, a claim like that can only be interpreted as a challenge! :)
Investigation & findings
The CO2 sensor inside the CO-100 (in the left of the picture) has a sticker saying ZGw063RY. Googling for this number reveals a CO2 module that looks just like the Voltcraft CO-100, so it appears that the CO-100 is basically a rebranded ZyAura ZGw063RY module.
The CO-100 seems to miss a bunch of components that can be mounted on the PCB, close to the RJ45 connection (most likely an RS232 chip with charge pump capacitors).
The CO2 sensor in the CO-100 is a ZyAura ZG-01 module. This sensor uses the ZyAura protocol, which vaguely resembles SPI, see Bestand:ZyAura CO2 Monitor Carbon Dioxide ZG01 Module english manual-1.pdf.
On the bottom left of the PCB is a set of pads that are marked with G, C, D, V, meaning Ground, Clock, Data, Voltage of the ZG01 sensor. The voltage level on the clock and data pins is 3.3V (the voltage on V pin is 3.3V too).
The ZG-01 sends 5-byte frames containing measurement values:
- byte 0 is an identifier for the measurement item, e.g. whether it is a CO2 ppm value or a temperature.
- byte 1 and 2 contain the value of the item (byte 1 is the MSB, byte 2 is the LSB)
- byte 3 is a checksum over bytes 0-2, just the sum modulo 256.
- byte 4 is always 0x0D
Besides the CO2 ppm value and temperature, it also sends various other (so far unknown) measurement items.
Measurement items encountered so far:
| Item | Value | Remark |
| 0x41 'A' | 3290 | Relative humidity in units of 0.01% |
| 0x42 'B' | 4708 | Temperature in Kelvin (unit of 1/16th K) |
| 0x43 'C' | 2964 | ? |
| 0x46 'F' | 6882 | Temperature in degrees Fahrenheit (unit of 0.01)? |
| 0x4F 'O' | 7754 | ? |
| 0x50 'P' | 857 | CO2 concentration in ppm |
| 0x52 'R' | 10438 | Barometric pressure? |
| 0x56 'V' | 10443 | Barometric pressure? |
| 0x57 'W' | 7880 | ? |
| 0x6D 'm' | 2559 | Seems to always have same value |
| 0x6E 'n' | 17146 | ? |
| 0x71 'q' | 855 | Always close to value of item 0x50 |
Integration into Revspace infrastructure
Measurements of the CO2 meter are integrated into the existing infrastructure as follows:
- The G, C, D, V lines from the ZG-01 have been broken out using a standard 2.54mm pitch header
- The ZG-01 ground, clock and data lines are attached to an arduino which decodes the ZG-01 protocol
- Also attached to the arduino is an NRF24L01+ wireless transceiver, through which the CO2 measurement is sent to a central receiver (the one that also handles the Nomz-bell, Skip-button, etc.).
The ZG-01 module and NRF24L01+ transceiver are connected to the Arduino as follows:
| Arduino | Module | Remark |
| D2 | ZG-C | ZG01 clock signal |
| D3 | ZG-D | ZG01 data signal |
| GND | NRF-1, ZG-G | NRF ground, ZG01 ground |
| 3V3 | NRF-2 | NRF power |
| D8 | NRF-3 | NRF CE |
| D9 | NRF-4 | NRF CSN |
| D13 | NRF-5 | NRF SCK |
| D11 | NRF-6 | NRF MOSI |
| D12 | NRF-7 | NRF MISO |
| - | 8 | NRF IRQ - not connected |
The basic function of the software on the arduino is to wait until a CO2 measurement is received from the ZG-01, then send it using the wireless transceiver.
The source code can be found on github. This archive contains two arduino projects:
- one for an Arduino Pro Mini, using an NRF24L01+ for the wireless connection
- one for an ESP8266, sending measurement values directly to MQTT over the WiFi.
ZG-01 decoding
The ZG-01 protocol is decoded using a simple state machine. On each falling edge of the clock line, a sample of the data line is taken until a total of 40 bits is received. If the time between a bit and the previous bit is longer than 2 milliseconds, it is assumed that a new 5-byte frame has started.
Wireless protocol
NRF
To control the NRF24L01+ wireless transceiver, we use the gcopeland fork of the RF24 library. This library has several important fixes over the original RF24 library (and is used in the receiver as well).
The wireless message consist of 7 bytes:
- 0x06 "CO_2" <MSB> <LSB> for the CO2 concentration message (in ppm)
- 0x06 "HUMI" <MSB> <LSB> for the relative humidity message (in units of 0.01%)
ESP
The ESP version of the software uses MQTT to publish the measurement values, on the following topics (retained):
- revspace/sensors/co2 with the CO2 concentration in ppm
- revspace/sensors/humidity with the relative humidity in percent
Heat map generation
Flok420 is generating heat maps. keetweej.vanheusden.com/revspace/co2.php He also has a large data set you might be able to use for your own data-mining purpose.
