EspWifiTracker
Revision as of 14:18, 20 March 2016 by Bertrik Sikken (talk | contribs)
Project EspWifiTracker
Location-tracker based on WiFi station ids
Last Update 2016-03-20
  • 2016-03-17 Can't really get the wake-up using the DS3231 to work, the interrupt pin appears to be active all the time, keeping the ESP in reset.
  • 2016-03-16 Working on a prototype using a NodeMCU with a DS3231 RTC
  • connect the RTC to the reset line of the ESP and get the mechanism going where I program an alarm in the RTC, make the ESP sleep and make it wake up by the alarm
  • create a kind of blacklist/whitelist mechanism that scores each scanned AP for suitability to connect to the internet, based on AP name / security type / whether we know the password / etc. A negative score could mean that it should definitely NOT try to connect using a specific AP. The AP with the highest score is tried first
  • track your own bicycle
  • know where your cat goes
  • monitor movement of wild animals for research purposes, like bats or stone martens.
  • the tracker is in deep-sleep most of the time, keeping only a low-power real-time-clock running.
  • every once in a while (say once a day) it wakes up, takes a reading of all WiFi stations in range and their signal strength. It stores these in internal memory.
  • if the tracker wakes up to find an open WiFi station (or one that it knows the WiFi password of), it tries to upload all previous readings to a server.
  • the server resolves the uploaded data into geographical locations using a service like Google or the Mozilla Location Service.
Tracker prototype
I'm working on a prototype of this.
I'm basing this off an inexpensive NodeMCU clone. The NodeMCU is basically an ESP8266-module on a break-out board with an USB-serial converter and a proper 3.3V power supply. The ESP8266 is a WiFi-capable microcontroller, capable of running at 80 MHz, it has 1 MB (or more) of flash onboard which enough spare flash sectors to hold a file system.
To wake up periodically, I'm using a ZS-042 clock module, containing a Maxim DS3231 RTC chip (datasheet). This module is attached to the NodeMCU through the I2C-bus on pins D1 (SCL) and D2 (SDA). When the RTC alarm triggers, the RTC resets the ESP8266, I have yet to try this.
The NodeMCU can be conveniently programmed from the "Arduino" development environment using the Arduino core for ESP8266 WiFi chip
Other libraries used:
It runs a simple command interpreter, type 'help' at 115200 bps to get a list of supported commands.
AP selection
  • first, try a secure network that we know the password of;
  • next, try an open network that we know is open to the internet (probably very rare...);
  • ignore any open network that we know is not really open or uses a captive portal (like "KPN Fon")
  • try any open network that is unknown to us.
  • {score=100, ssid="my_home_network", pass="my_home_pass"}
  • {score=100, ssid="my_work_network", pass="my_work_pass"}
  • {score=-100, ssid="KPN Fon", pass=""}
  • {score=-100, ssid="WiFi in de trein", pass=""}
  • {score=-100, ssid="McDonalds FREE WIFI", pass=""}
  • {score=0, ssid="*", pass=""}
main program flow
  • read the RTC to determine if it's time to do a scan, else go to sleep again
  • scan wifi networks
  • append the results of the scan to file, the file name is based on the current date.
  • score each network for suitability for upload, if none is found, go to sleep again
  • connect to the network and probe for actual internet connectivity
  • upload the log files one by one, delete the file if successful
  • download new settings files
  • try to perform an NTP sync and update the RTC if successful
  • go to sleep.
data structures
Server backend
  • one to upload collected WiFi data from the tracker to the server
  • one to download configuration data from the server to the tracker
  • a new periodic wake-up schedule
  • list of known WiFi stations + passwords
  • WiFi station whitelist, list of stations which are known to be really open to the internet
  • WiFi station blacklist, list of stations which are open (unencrypted), but not really open to the internet
Challenges
Some things to solve yet:
  • first of all make a working prototype, not necessarily optimized yet for size / appearance / battery usage / etc
  • when using "WiFi hotspots": figure out how to handle so-called captive portals. Many open access points spoof DNS after connecting to the access point and re-direct you to a webpage where you either need to log in or click some 'I agree' button. It's easy for a human to understand this, possibly not so easy for an embedded device.
  • figure out how to run everything from a battery, like can we run it directly off an LiFePO4 battery, or use a lithium-cobalt battery with an LDO, etc.
  • make it lower power: so we can use a smaller battery or get longer tracking time
  • make it smaller and lighter: so it can be attached to smaller items (e.g. a migrating bat)
