Spacenet/mobileconfig
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>PayloadContent</key> <array> <dict> <key>AutoJoin</key> <true/> <key>EAPClientConfiguration</key> <dict> <key>AcceptEAPTypes</key> <array> <integer>21</integer> </array> <key>EAPFASTProvisionPAC</key> <false/> <key>EAPFASTProvisionPACAnonymously</key> <false/> <key>EAPFASTUsePAC</key> <false/> <key>TTLSInnerAuthentication</key> <string>PAP</string> </dict> <key>EncryptionType</key> <string>WPA</string> <key>HIDDEN_NETWORK</key> <false/> <key>PayloadDescription</key> <string>Configures wireless connectivity settings.</string> <key>PayloadDisplayName</key> <string>Wi-Fi (spacenet)</string> <key>PayloadIdentifier</key> <string>revspace.wifi.wifi</string> <key>PayloadOrganization</key> <string></string> <key>PayloadType</key> <string>com.apple.wifi.managed</string> <key>PayloadUUID</key> <string>AFCEF054-D849-4520-959C-92593FA76DC6</string> <key>PayloadVersion</key> <integer>1</integer> <key>ProxyType</key> <string>None</string> <key>SSID_STR</key> <string>spacenet</string> </dict> </array> <key>PayloadDescription</key> <string>Profile description.</string> <key>PayloadDisplayName</key> <string>revspace</string> <key>PayloadIdentifier</key> <string>revspace.wifi</string> <key>PayloadOrganization</key> <string></string> <key>PayloadRemovalDisallowed</key> <false/> <key>PayloadType</key> <string>Configuration</string> <key>PayloadUUID</key> <string>B8B57C95-2D5B-4376-AFCF-2D99404C397C</string> <key>PayloadVersion</key> <integer>1</integer> </dict> </plist>
