ZX81PLUS35 ZX81 clone
As for now comments and questions on the design can be made here [2] (raspberry PI forum off topic section)  :-)
Introduction to the ZX81+34
The ZX81+34 is a much improved ZX81 that people can build themselves.
The ZX81+34 should be fully compatible with the original ZX81, but with the following improvements over the original ZX81 :
  4. Supports ZX81 BASIC in either a EEPROM or in an OTP (one time programmable ROM)
  9. Can drive a simple LCD display, and some external I/O for "stand alone" applications like driving tiny robots. Debug LED/Backlight LED support.
Current Status
At the moment the PCB of the first prototype has been designed, and is ready to be tested.
3D Preview of early ZX81+34
The botom picture also shows the four chips of the original ZX81, and what replaces them on the ZX81+34, green is the Z80 CPU, RED the (EE)PROM, Yellow the RAM (1K on the ZX81, 16/32K on the ZX81+34). Blue indicates the logic of the ULA, contained in a single 40-Pin IC on a ZX81, the ZX81+34 replicates it with 24 conventional but modern logic ICs.
Schematic 81+34
The latest schematic (.PDF) can be found here: File:ZX81+34 schema.pdf
There is also a color coded schematic (.PDF), it can be found here: File:ZX81+34 kleur REV 2.0.pdf.
The Bill of Material (BOM) for the ZX81+34 can be found here File:Z81+34 BOM.ods
Layout ZX81+34
Keyboard for ZX81+34
File:Nieuw keyboard ZX14.pdf
Alternative font for ZX81+34
The final ZX81+34
Here is a drawing to help assembling the right components at the right places (A placement drawing), it was made from the real silkscreen gerber-file (in red)comments and component values in black.
Starting the assembly
Finished assembly
Testing (continued)
After I finally managed to program an EEPROM, I started testing the device, unfortunately disaster struck immediately! I could not get the device powered up, and after some searching I found out I made a mistake in the creation of the footprint of the microUSB connector, that caused the reversal of the GND and 5V pins. This means that for some time (minutes) the whole device was fed with negative 5V, a disaster! From previous experience I know that most CMOS devices can survive this, with the exception of (older types) of EEPROM's which are often erased by feeding the wrong polarity of signals. The EEPROM used 28HC256 is more modern, so I have some hope it has survived, time will tell. P.S. I have since verified that the EEPROM indeed was not affected! Normally I add protection in the form of a 1N4001 diode between +5V and GND, but because voltage inversions normally cannot happen with an USB fed design I failed to take that precaution. :-(. A very bad start indeed, its possible that any and all CMOS logic was destroyed.
After fixing the polarity problem, (with a nasty patch consisting of first using the microUSB connector upside-down, later replacing it with a short cable to a type B USB port) I tried powering on again, and 5V came up with just 100mA consumption, but no life in the system. I found the main (13MHz) crystal oscillator was not running, and the problem seemed that the footprint for the crystal was for a 5 x 7mm device, while the only 13MHz crystal I could find was a 5 x 3mm device. The crystal seemed not to make contact. I replaced it for one that could be soldered to the edges of the crystal, but the oscillator still did not ran! I tried replacing the 33pF load capacitors with 15pF ones, but no luck. The "tiny logic" inverter used in the oscillator seemed to work with static logic signals, but did not want to oscillate, perhaps it was "blown up", I replaced it, and after some effort the oscillator proved to be working (jay!). I followed the clock signal through the timing chain, and it seemed to be working in all the SO-logic devices, but when it came to the last buffer before clocking the Z80 that tiny logic buffer U25 failed! It was in a difficult place to desolder, and I had no replacement, so I arranged for a new one, to be de-soldered at work, where I can re-work with hot air under a microscope. Meanwhile the microUSB connector had fallen off the board (sigh, ripped of is a better description), and was replaced by a contraption with a normal size USB type B connector on a small PCB, its ugly but it works.
With the Z80 not running, I tried to debug the Z80 logic, and found that the very first instruction the EEPROM does after reset is an OUT,&FD instruction, but the OUT,&FD was not happening! Perhaps the Z80 was blown up. I found a bug, namely the reversal of VCC and output pins of U17 (single gate OR), I fixed that with a patch, but the OUT&FD was still not happening. I replaced the Z80 with an old 4MHz Z80 I had, but with no luck (no video). Careful examination of the schematics revealed a few other errors, explaining the lack of video. The SH/LD signal must be driven by pin 8, not pin 9 of U29B, The CSYNC signal should be an XOR of VSYNC and the inverted HSYNC, not HSYNC itself, so pin 1 of U21a must be tied to pin 11 not pin 13 of U21C, also the clock inputs of U28 were not driven by the /WR signal, as they should have. So I added the corrections to the schematic, and also switched the OTP in the schematic to the EEPROM I used. I posted the new revision 2.0 schematic here, and patched the board. I must still test if the patches I found, and the new Z80, have solved the problem, If not, I have to resort to using a logic analyser to find the problem, that would be a bummer! to be continued..... I finally gave up and tried a (simple) logic analizer, and quickly found that half the databus signals were permanently low. some databits, but not all, seemed to be driven low permanently by U1, the NOP driver. after renoving U1 the databus seemed okay, but replacing U1 with a new one did not solve the defect. That was the moment I decided not to search for more defects, but to create revision two of the ZX81+34 (even when it meant it would become a ZX81+35) .
So without further ado, I present the first changes for ZX81+34 rev 3.0.
ZX81+34 rev 3.0
