InductionHeater
Versie door Semafoor (overleg | bijdragen) op 8 sep 2014 om 11:26 (Added Inverter schematic)
Project InductionHeater
Status Initializing
Contact smeding, gori
Last Update 2014-09-08
Idea is to make a 3kW induction spool to smelt metals and heat steel for forging. For examples see :
Inverter circuit
Smeding came up with the following circuit:
Values of all components are to follow shortly. The accompanying BOM looks something like this:
Component cost
Bridge rectifier €2.56
switching transistor €22.92
Tank capacitors 20.50
DC link filter capacitor €23.14
Gate driver €7.06
Couple transformer Toroid €20 (est.)
Gate drive transormer toroid €3
Estimate for components killed (see below) €60
Total €160
Based on Smedings estimate Obviously, some parts may die a gruesome death during construction and testing. Worst case estimate is that the switching transistor and the driver will die twice, adding an amount of €60 to the BOM before we have a working machine.
Additional hardware
In addition to the inverter circuit, at least the following things are needed to make a working induction heater
Component cost Possible sources requirements
Coil 1 small diameter for smelting € 15 ? Gas tubing, car brake tubing Copper. Sufficient copper area to handle the current. Sufficient inner area + diameter to allow for effective cooling
Coil 2 large diameter, 30cm for forging, between 5 and 10m € 25 - 50 Gas tubing, 15 mm car brake tubing Copper. Sufficient copper area to handle the current. Sufficient inner area + diameter to allow for effective cooling
heat exchanger €15 ? Car junkyard Unsure how much heat needs to be removed and at what temperatures. Worst Case would be 3 kW. A car radiator is probably good (cheap, sufficient power and an integrated fan)
Pump €20 Possibly a pump from a domestic heater (CV). Buy for around €20 on Marktplaats Have to check whether or not normal sizes create sufficient flow through small diameter coil tubing
Electrical connections and wiring € 20 Battery connections form scrapped cars? How much current do we expect, and how long do the wires have to be? how do we connect these to the coil tubing (Earth blocks?
Tubes and other cooling connectors 15€
Total cost € 85 (incomplete)
Total cost
cost
Inverter €160
Hardware €85
Total €245
Now we need financing. The current total is €245, and that isn't complete so far (although it may get close)
Pledges:
  • Gori: 50 euro
  • Flok: 10 euro
  • Walter: 50 евра
  • FooBar: €20
  • bertrik: €10
  • Semafoor: €20 (more if the project is better defined)
