DebiSampler
| Project DebiSampler | |
| Contact | TheOnlyJoey |
| Last Update | 2012-01-16 |
DebiSampler is a project to create a Stage Synthesiser based on off the shelf hardware with some customising and creativity, Debian and the Linuxsampler software.
| To Do | Description | Status |
| Basic Board Installation | Install and Config: Debian, Xorg, OpenJDK, Debisampler, Alsa, Jack | Done |
| NVIDIA + RT Kernel | Customise and Compile the NVIDIA driver against the Realtime Kernel | Done |
| Order and Install SSD | Change the CF card with cheap Transcend SSD (Thanks foobs!) | In Progress |
| Startup script | Create startup script using SH, init jack with commands, start linuxsampler, start Xorg with Fantasia java interface | Done |
| LSCP Script | Create a LSCP startup script to automate Linuxsampler (init jack, connect midi, create track etc) | In Progress |
| Sample Cards | Order and Install multicard-reader with auto mounting to /samples with 775 permissions | Planning |
| Plexiglas Heater | Create a Plexiglas heater and bender for the Casing (example: http://farm1.static.flickr.com/39/87088389_54772d8cf9.jpg) | Planning |
| Bend Casing | Bend the casing for the synth | Planning |
| Install Touchscreen | Order and install the 7" touchscreen | Planning |
| Customise GUI | Borrow a coder to customise the Jsampler/Fantasia GUI | Planning |
| Plugs | Order and Install XLR and Jack outputs, external MIDI etc | Planning |
| Install the rest! | Place and install all the additional hardware | Planning |
| Paintjob | Make everything sparkly | Planning |
