Its-g5
| Project ITS-G5 | |
| Receiving ITS-G5 signals | |
| Last Update | 2026-07-30 |
Stuff to investigate:
- Crowd-sourced live map of messages received: https://opentrafficmap.org/ Their wiki: https://wiki.opentrafficmap.org
- Source code for an ITS-G5 receiver https://github.com/pit711/v2x2map
- Simplest source code for Arduino-based sniffer: https://git.devlol.org/jstsmthrgk/simple-its-g5-receiver-firmware
Design
The design is:
- Use an esp32-c5 for sniffing 802.11p frames only
- Use an esp32-c3 for receiving sniffed frames from the esp32-c5, connect to WiFi and upload packets over MQTT
- The interface beteween the two boards is serial, this is simpler than SPI as used in other projects:
- Only three wires required: GND, +5V and serial DATA
- No hardware modification required (e.g. desolder capacitors on SPI wires of the esp32-c5)
- A serial interface is more universal, e.g. can be connected to an arbitrary linux SBC, to run a python bridge for example
- On the esp32-c5 use the same wires as the existing USB-UART bridge, so you can also receive packets over USB-serial
- Run a simple web server on the esp-c3:
- Configuration page with MQTT settings: protocol, host, port, user, pass
- Optional: show some nice stats: mqtt status, packet rate, last packet, packets per type
- Optional: run a very basic parser for e.g. CAM messages
- Power is provided to the esp32-c3, which then distributes power as raw 5V/GND to the esp32-c5. The esp32-c5 uses its own regulator to turn it into a stable internal supply voltage.
Practical:
- The serial link runs over the USB-UART chip of the esp32-c5.
- A simple command processor runs on the other UART (the emulated USB serial port)
- On the esp32-c5 side, use pins GND, 5V, UART-TX for the ESP-ESP serial connection.
- The esp32-c3 and esp32-c5 share their 5V and GND power lines. Each board derives its own internal power supplies from this 5V.
- The serial link doesn't have to be very high speed, 115200 for example. We use a hardware UART on both sides of the serial link.
- Use https://registry.platformio.org/libraries/thomasfredericks/MicroSlip for framing packets over the serial port.
opentraffic map interface
See https://github.com/MPW1412/openwrt-otm-bridge#wire-format-mimics-the-esp32-c5-firmware for the mqtt wire format.
See also https://github.com/pit711/v2x2map/blob/main/firmware/main/mqtt.c
In short: server = mqtts://cits1.opentrafficmap.org:8883 :
- no user name / password
- topic 'its/<node>/status' (online or offline), retained
- topic 'its/<node>/info' with a JSON string, like {"emac":"xx:xx:xx:xx:xx:xx","ver":"github.com/bertrik/its-g5-receiver-v0.0.1","hwv":"esp32-c5-devkit-c1"}
- topic 'its/<node>/packet' for sniffed packets (raw, not JSON encoded)
Sniffer
This project uses an ESP32-C5-devkitC-1 board for the sniffer part:
- Aliexpress product page https://nl.aliexpress.com/item/1005012416463528.html
- Espressif schematic https://dl.espressif.com/dl/schematics/SCH_ESP32-C5-DevkitC-1_V1.1_20240621.pdf . Actually my board is not exactly like this, the USB-UART is connected to pins GPIO11 (TX) and GPIO12 (RX), not GPIO25/GPIO24.
- Espressif devkit-c page: https://docs.espressif.com/projects/esp-dev-kits/en/latest/esp32c5/esp32-c5-devkitc-1/user_guide.html
It has an onboard antenna. There are also other boards with an antenna connection, which allows using an external antenna. This may be better, I don't know yet.
Bridge
An ESP32-C3 is used as the bridge part. I used a 'supermini'.
How to wire it up, what I did:
- Put both the esp32-c3-supermini board and the esp32-c5-devkit-c1 on a breadboard
- Use male-male dupont wires to connect:
- 5V to 5V, GND to GND, esp32-c5 TX to esp32-c3 RX
- Programmed the esp32-c5 with firmware
- Plug an USB-C cable into the esp32-c3, programmed it with firmware, now it's powering both the esp32-c3 and the esp32-c5
The esp32-c3 supermini apparently has a design flaw causing them to run very hot:
So in software you need to keep this in mind:
- lower the CPU frequency, makes a few degrees difference: this seems to make SSL network connections unreliable though
- allow some 'idle' time in Arduino, e.g. using delay(50) or delay(100) in loop()
| ESP32-c5 | ESP32-c3 | Remark |
| GND | GND | shared ground |
| 5V | 5V | raw power |
| U0TXD/GPIO11 | RX/GPIO20 | Data link |
See https://github.com/bertrik/its-g5-receiver
This is heavily inspired by https://git.devlol.org/jstsmthrgk/simple-its-g5-receiver-firmware but with a fixed size ring buffer instead of dynamic allocation.
Compiling the firmware
Uses python and platformio, see the README.md in the source archive.
Watch packets come in:
pio device monitor
Then viewed in wireshark:
wireshark message.pcap
