Its-g5
Project ITS-G5
Investigating ITS-G5 signals
Last Update 2026-06-22
wireshark analysis
Stuff to investigate:
Design
The plan is:
  • Use an esp32-c5 for sniffing 802.11p frames only
  • Use an esp32-c3 (as an inexpensive jellybean part) for receiving sniffed frames from the esp32-c5, connect to WiFi and upload packets over MQTT
  • The interface beteween the two boards is serial, this is simpler than SPI as used in other projects:
    • Only three wires required: GND, +5V and serial DATA
    • No need to desolder capacitors on SPI wires of the esp32-c5
    • A serial interface is more universal, e.g. can be connected to an arbitrary linux SBC, to run a python bridge for example
    • On the esp32-c5 use the same wires as the existing USB-UART bridge, so you can also receive packets over USB-serial
  • Run a simple web server on the esp-c3:
    • Configuration page with MQTT settings: host, port, user, pass, base topic
    • Perhaps configure a keystore/certificate for secure mqtt (mqtts), if needed
    • Optional: show some nice stats: mqtt status, packet rate, last packet, packets per type
    • Optional: run a very basic parser for e.g. CAM messages
Practical:
  • The serial link runs over the USB-UART chip of the esp32-c5.
  • A simple command processor runs on the other UART (the emulated USB serial port)
  • On the esp32-c5 side, use pins GND, 5V, GPIO25 for the ESP-ESP serial connection. These pins are right next to each other on the esp32-c5-devkitc-1. Pin GPIO25 is the pin that connects to the USB-UART chip.
  • The esp32-c3 and esp32-c5 have their 5V power lines connected together. Each board derives its own internal power supplies from this 5V.
  • The serial link probably doesn't have to be very high speed, start with 115200 for example. Try to use a hardware serial peripheral on both sides for this.
  • Probably use the Arduino PacketSerial library on both sides for framing/deframing packets.
esp32-c5
I got this board, and it worked for me:
It has an onboard antenna. There are also other boards with an antenna connection, which allows using an external antenna. This may be better, I don't know yet.
Connect your USB-C cable to the "UART" port. It is connected to an actual USB-UART converter chip and always shows up, regardless of whether the ESP32 is in reset or not.
See https://github.com/bertrik/its-g5-receiver
Compiling the firmware
Needs python.
Preparation:
  • If you didn't have a python venv, create it:
 python -m venv .venv
  • Activate the venv:
 bash source .venv/bin/activate
  • Install platformio into the venv:
 python pip install platformio
Compile and upload:
Watch packets come in:
 pio device monitor
Then viewed in wireshark:
 wireshark message.pcap
opentraffic map interface
See https://github.com/MPW1412/openwrt-otm-bridge#wire-format-mimics-the-esp32-c5-firmware for the mqtt wire format.
