Its-g5
Project ITS-G5
Investigating ITS-G5 signals
Last Update 2026-06-22
wireshark analysis
Stuff to investigate:
esp32-c5
I got this board, and it worked for me:
It has an onboard antenna. There are also other boards with an antenna connection, which allows using an external antenna. This may be better, I don't know yet.
Connect your USB-C cable to the "UART" port. It is connected to an actual USB-UART converter chip and always shows up, regardless of whether the ESP32 is in reset or not.
See https://github.com/bertrik/its-g5-receiver
Compiling the firmware
Needs python.
Preparation:
  • If you didn't have a python venv, create it:
 python -m venv .venv
  • Activate the venv:
 bash source .venv/bin/activate
  • Install platformio into the venv:
 python pip install platformio
Compile and upload:
Watch packets come in:
 pio device monitor
Then viewed in wireshark:
 wireshark message.pcap
opentraffic map interface
See https://github.com/MPW1412/openwrt-otm-bridge#wire-format-mimics-the-esp32-c5-firmware for the mqtt wire format.
