Its-g5
Project ITS-G5
Investigating ITS-G5 signals
Last Update 2026-06-20
Stuff to investigate:
I got this board, and it worked for me:
It has an onboard antenna. There are also other boards with an antenna connection, which allows using an external antenna. This may be better, I don't know yet.
Connect your USB-C cable to the "UART" port.
See https://github.com/bertrik/its-g5-receiver
Compiling
Needs python.
Preparation:
  • If you didn't have a python venv, create it:
 python -m venv .venv
  • Install platformio into the venv:
 python pip install platformio
  • Finally activate the venv:
 bash source .venv/bin/activate
Compile and upload:
Watch packets come in:
 pio device monitor
Then viewed in wireshark:
 wireshark message.pcap
