Karaburan
| Project Karaburan | |
| Monitoring water quality | |
| Last Update | 2026-05-11 |
engage with PX4 community on getting a feel if this is useful to use and if so, how to get startedfigure out how to duplicate an MQTT streamdon't bother- write python scripts
arduino turbiditydon't botherturbidity-to-mqttmaybe make this ROS moduleHID-to-mqttmaybe make this ROS module- position/velocity listener script: latitude, longitude, altitude, heading/bearing/track/whatever, velocity
- analoog in op de pi:
- 1-wire stuff:
- Figure out the udev/hotplug mess, we probably need this because many of our peripherals use a serial port:
- in how many places can we store the udev renaming logic (config files)
- can we automate this, make it user friendlier, e.g. some kind of "insert device X now" script
Check:
USB HID as analog input
- install openocd
sudo apt install openocd
- watch the kernel logs
sudo dmesg -w
Verify that it works:
- install the evtest package
- run
influxdb
ROS
Investigation:
- Using gpsd:
- install ros-jazzy-desktop
Topics:
- air quality sensors
- ammonia
- NOx
- water chemical analysis
- nitrates
- ammonia
- dissolved oxygen
- sulfide/sulfate
- phosphates?
- salinity (chlorides?)
- water physical analysis
- temperature
- depth?
- boat control
- trajectory -> steering
- camera control
- post-processing
- data presentation
- video/photo stitching
- time lapse view
- map view of properties
- data presentation
- use cases
- minimum viable prototype
- materials
- boat selection
Investigate RTK GPS
- Chipsets
- uBLOX ZED-F9P
- Boards
- UM980 / UM982
- stop gpsd.socket
- run from command line
Validation
Comparison with reference coordinate
On october 4th 2024, we took the RTK GPS to a kernnet reference point at 51.99712236/4.68886324, results below:
From https://www.nsgi.nl/iv-api/rdinfo/rdpoint/389346:
- Year 2021: "51 59 49,64004", "4 41 19,90584", 48.039. In decimal degrees that is
| Reference 2012 | 51.99712236 | 4.68886324 | - | - | 0 | by definition |
| Reference 2021 | 51.99712223 | 4.68886273 | - | - | 0 | by definition |
Air quality sensors
Nitrogen compounds in air
- NOx: 27.3 ug/m3
- NO2: 18.6 ug/m3 (9.9 ppb)
Sonar sensors
Investigate this because it allows us to measure depth.
AliExpress has several types of affordable sonar sensors, focused at detecting fish, but also able to measure depth.
I ordered this one: https://nl.aliexpress.com/item/1005006388343879.html
- 125 kHz main frequency, range up to 200 ft deep (about 60m)
- bluetooth low-power interface (basically serial-over-BLE)
- built-in battery, powers on automatically when submerged
- reports 120-element array with raw sonar return intensity-vs-depth
- measures water temperature
- about 45 euro
Fish helper pro application for android https://apkpure.com/fish-helper-pro/com.fishfinderpro.xdx
Debug tool
I wrote a python script to connect to it from a linux computer: https://github.com/bertrik/wireless-sonar-sensor
It's connects to a "Fish Helper Pro" wireless sonar sensor over bluetooth low-energy, reports depth and temperature
ROS2 integration
The most appropriate message for a simple range would be: https://docs.ros2.org/foxy/api/sensor_msgs/msg/Range.html
There are other messages to perhaps report the raw echo return array.
Water physical analysis
Turbidity / clarity
Water measurement probes
- https://nl.aliexpress.com/item/1005003784454381.html BLE-9908 Inexpensie "Yieryi" PH/EC/Temp probe with bluetooth and app, about E25,- (Uses 3x LR44 coin cell batteries)
- Several different models: https://nl.aliexpress.com/item/1005007810989801.html
- EZ9901: TDS/pH/temp
- EZ9902: EC/pH/temp
- EZ9908: EC/TDS/pH/temp
- EZ9909: TDS/EC/pH/salt/temp
- The bluetooth versions are probably as above, with numbers like BLE9902 and BLE9908
- Yiery BLE9902: https://shop.yieryimeters.com/products/yieryi-ble-9902-3-in-1-digital-ph-meter-with-bluetooth-ec-and-temperature-measurement-ideal-for-water-quality-testing-in-pools-fish-tanks-hydroponics-more
- BLE-EC01 is a bluetooth EC meter, can find it here https://www.amazon.com/BLE-EC01-Smart4-TDS-Temp-Meter/dp/B0DPZZC7BV, not on AliExpress?
Note:
- Some probes indicate EC (electrical conductivity), other indicate TDS (total dissolved liquids). TDS is derived from EC (knowing the liquid type). EC is the more universal/fundamental property!
- EC is typically expressed in uS/cm or mS/cm (micro or milli siemens per centimeter), say 500 uS/cm for outdoor water.
- EC is temperature dependent, typically you need the value extrapolated to 25 degrees Celcius. Temperature-EC correlation rule of thumb: about 2% more conductive per K.
- pH sensors are almost by definition fragile and last only a limited time, so probably don't bother trying to use one at all. The pH of outdoor water might not be that interesting to measure.
- I expect the non-TuYa meters to use an easier to handle bluetooth protocol, avoiding the need for complicated encryption with a key that can only be fetched for a limited time using a tuya developer account.
BT785
I bought this one: Tuya compatible BT785 EC meter: https://nl.aliexpress.com/i/1005007462079781.html inexpensive, focused on EC, runs on 4x LR44. Speaks the TuYa protocol (requires a secret key that you can fetch through the developer console). This is quite cumbersome: you have to register as a developer, fetch the key before time runs out and developer access is limited.
Does NOT speak the universal serialport access protocol as described here: https://developer.tuya.com/en/docs/iot/tuya-cloud-universal-serial-port-access-protocol?id=K9hhi0xxtn9cb
More information on this wiki: https://revspace.nl/BT785 Code: https://github.com/bertrik/bt785
Cheap non-bluetooth EC/TDS
I got this one: https://nl.aliexpress.com/item/1005007267608479.html
Tear-down on hackaday: https://hackaday.io/project/184764-ectds-temp-meter-teardown
Boat control
- 2.4 GHz working frequency
- 500m range
Interesting links:
remote control
Parts:
Use cases
material:
Reeuwijkse plassen
See
potential applications:
Detect/find pollution source
Implementation
udev handling of serial ports
The udev config file is:
/etc/udev/rules.d/99-usb-serial.rules
# LIDAR serial converter
SUBSYSTEM=="tty", ATTRS{idVendor}=="10c4", ATTRS{idProduct}=="ea60", SYMLINK+="ttyLIDAR", MODE="0660", GROUP="dialout"
# quectel GPS
SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", SYMLINK+="ttyGPS", MODE="0660", GROUP="dialout"
# ublox GPS
SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", SYMLINK+="ttyGPS", MODE="0660", GROUP="dialout"
An USB-nano also appears to have a USB vendor/product id of 1a86/7523 ("USB2.0-Serial") ... same as the quectel GPS?
Same for "AI thinker" USB-serial: vendor/product id of 1a86/7523 (product: "USB2.0-Serial")
To (re)load the properties:
sudo udevadm control --reload-rules
reading temperature sensor
Preparation:
sudo adduser <name> dialout
Setting up the hardware:
Setting up the software:
- Install openwire fs
sudo apt install owfs
sudo mkdir /mnt/1wire
- Configure systemd services
- Start the systemd service
- Check the logs
