RevKlanet
| Project Revklanet | |
| Contact | Gori, PeterC |
| Last Update | 2024-02-22 |
The project to make DIY Alklanet aka RevKlanet, AlklaNEP, Lolklanet or Alklanetniet. Why ? Alklanet is awesome cleaning agent, but is kinda expensive. Can we make something ourselves? Alklanet is a commercial product, with a secret composition. Howewer the MSDS reveals the most common chemicals.
Alklanet facts
- blue
- pH 5.5 - 7 according to MSDS, Litmus measures 6
- 5 -10% 2-Butoxyethanol
- ? % surfactant
- ? % ethanol
Recipe V0.1
Al %weight, For 200 ml. These will give only approximate concentrations.
- 20 g Eco-Aceton from "De Parel" from hornbach
- 10 g hard soap
- 10 g ethanol (Available from drugstores as 95% ethanol for cleaning)
- 160 g water
Feedback
- Trouble dissolving all the soap, also feels very soapy, probably way too much.
- pH 8
- thrashed
Recipe V0.2
- 2 g hard soap (Nivea creme soft)
- 10 g ethanol ( 96% ethanol from Etos)
- 168 g water
Feedback
- smells very nice
- cleans well, but less than Alklanet or 0.3
- leaves a bit more streaks than Alklanet
Recipe V0.3
Composition
For 200 ml solution, all wt%. These will give only approximate concentrations, as non of the ingredients are pure.
- 20 g ( 10% ) Eco-Aceton from "De Parel" from hornbach
- 5 g ( 2.5% ) mirasol 2000 - tenside / wetting agent. MSDS
- 10 g ( 5%) ethanol ( Available from drugstores as 95% ethanol for cleaning)
- 172 g ( 82% ) demineralised water
Economics
| Product | Price per unit (€) | Unit (g) | Price (€/g) | Amount in recipe (g/l) | Costs (€/l) | link |
| Eco-Acetone | 6.80 | 1000 | 0.0068 | 100 | 0.680 | https://www.pearlpaint.nl/nl/merken-producten/eco-line/aceton-eco_586/ |
| Mirasol | 11.95 | 250 | 0.0478 | 25 | 1.195 | https://www.macodirect.de/en/chemistry/machine-chemistry/4690/tetenal-mirasol-2000-antistatic-wetting-agent-250ml MSDS |
| Ethanol | 2.29 | 100 | 0.0229 | 50 | 1.145 | https://www.boodschappenbestellen.com/bestel/etos-alcohol-96/ |
| Demiwater | 2.65 | 5000 | 0.00053 | 825 | 0.437 | https://www.makro.nl/cat/nl/products/product/1522040001001 |
| TOTAL | - | - | - | 1000 | 3.46 |
- 3.46 per liter that is approx 1/2 of Alklanet price, 7,50 €/l (https://www.123schoon.nl/Ecolab-Alklanet-1-liter-i2477.html)
- This is very expensive since we are using most expensive source of ethanol and surfactant comes from a photographic materials supplier.
Feedback
- pH 6-7
- Gori: Cleaned the outside glass of the door in the workshop. Seems to remove mystery spots better than Alklanet
- Gori: when used on a tables, no perceivable difference.
- joepie91: v0.3 lijkt prima te werken, net tafel mee schoongemaakt, beetje vreemd geurtje maar verder prima
- Cleans very well, but leaves slightly more streaks than 0.2 (visible only on high gloss surfaces such as mirrors)
- Na een half uurtje schoonmaken geirriteerde neus en keel
Recipe V0.4
For this version, we want to
- improve the economics
- keep performance similar
- reduce chance of irritation of the eye/throat/nose
Ways to do that :
- Half the concentration of 2-Butoxyethanol
- Replace ethanol with a lower concentration of Isopropyl alcohol : Better degreasing properies, much cheaper, but somewhat more irritating
- Find an alternative surfactant / tenside, in bulk 1/10th of the price may be possible. Maybe Green soap
Composition
For 200 ml solution, all wt%. These will give only approximate concentrations, as none of the ingredients are pure.
- 5 g ( 2.5% ) "Driehoek" Green soap
- 10 g ( 5%) IPA ( Available from Revspace, 4 EUR / l)
- 165 g ( 82% ) demineralised water
Recipe V0.5
Back to the basics!
- 7.5% v/v pure 2-butoxyethanol in distilled water
I (thomas) tried to find food coloring suitable for revklanet 0.5 at various stores around the area, but alas, they all contained either propylene glycol (as solvent, which would leave streaks) or water with PH bufferring salts (which would leave residue). So we'll just have to make our own coloring, too.
Testing
- Test setup :
- Compare : Demineralised water, Alklanet, RevKlanet V0.2, RevKlanet V0.3
- Testing protocol :
- Apply and dry for 30 minites
- Wok oil
- Ketjap Manis
- Ketchup
- Meggele garlic butter
- Attempt cleaning with a clean microfibre cloth and report results
- Spray area with a single pump (we are using old Alklanet bottles)
- Wipe 1/3 immediately in a single downward stroke
- Wait 10 seconds then wipe 2nd 1/3 with a single stroke
- Then clean the final 1/3 until clean
- Then clean the entire area with the same product
Results V0.2 and v0.3
- Overall findings : Both V0.2 and V0.3 work as good as Alklanet. V0.3 dries fastest, and degrease markedly better than Alklanet. Probably because we use the a higher concentration of alcohols, and the wetting agent greatly helps as wel.
