GridFrequency
Versie door Bertrik Sikken (overleg | bijdragen) op 16 mrt 2023 om 13:37 (Created page with " {{Project |Name=MainsFrequency2.0 |Picture=netfrequentiemeter.jpg |Omschrijving=A simple mains frequency counter |Status=In progress |Contact=bertrik }} ==...")
(wijz) ← Oudere versie | Huidige versie (wijz) | Nieuwere versie → (wijz)
Project MainsFrequency2.0
Last Update 2023-03-16
This page is a reboot of this earlier main frequency counter.
Concept
Desired end result
  • get more accurate frequency measurement
  • get more responsive frequency measurement, i.e. instantaneous value, not a running average over 50 seconds.
Algorithm for getting accurate instantaneous frequency out of it:
  • Sample the mains frequency waveform during approximately one second (say 5 - 10 kHz)
  • Determine the median, lower and upper quartiles of the waveform, and shift data so its values are symmetrically around zero
  • Calculate zero crossings by doing linear regression to find the zero-crossing of the wave in the region around the zero crossing (in between the quartile values), this gives sub-sample time resolution
  • The linear regression runs a kind of state machine, just keeping track of sum(x), sum(y), sum(x*x), sum(x*y) is enough to perform a linear regression at any time
  • Do this over the approximately 50 cycles contained in the one second data and determine average frequency
