Stofradar
Project Stofradar
Visualizing atmospheric particulate matter concentrations on a map
Last Update 2021-09-05
See also my DustSensor page.
The website sensor.community is an initiative to allow citizens to participate in measuring atmospheric particulate matter concentration using an inexpensive and easy to build sensor. They collect this data, calculate 5 minute and daily averages and publish it again as open data. The total number of sensors is > 10000 worldwide, most of them in Germany, Bulgaria, Belgium, Austria, Sweden. The Netherlands has > 1000 sensors. See also [1].
Future activities:
  • find a universally agreed-upon color scale, and add a legend
  • investigate why sometimes an image cannot be calculated (API not accessible?)
  • plot official luchtmeetnet measurements on the map too, access to the API has been implementedwork in progress
Visualisation
Background map
Interpolation
  • calculate the "km-per-degree-latitude" at the middle for latitude as 40075 km / 360 degrees;
PM10 values < 0 ug/m3 are ignored in the software.
Colour range
Luchtmeetnet ranges
Correction for high humidity
Humidity generally seems to cause an overestimation of PM measurements for measurements done with a "particle counting" type of PM sensor. The effect become really significant above approximately 70% humidity.
Compositing
I use imagemagick for this, for example:
 composite -compose over -geometry 600x800 20180605_210100.json.png netherlands.png output.png
where netherlands.png is an 600x800 opaque black-and-white image of the map of the netherlands and 20180605_210100.json.png is an 60x80 image of dust concentrations with an alpha channel
Animation
  • GIF animation composed of hourly images over the past 24 hours
  • WEBM animation composed of 5-minute images over the past 24 hours
You can click on the GIF animation to view the WEBM animation.
