CNC plasma cutter
Versie door Smeding (overleg | bijdragen) op 6 nov 2012 om 02:26 (Initial page)
(wijz) ← Oudere versie | Huidige versie (wijz) | Nieuwere versie → (wijz)
After acquiring a plasma cutter at the space, it seemed only logical to try and fabricate a CNC version eventually.
This goal is still a while away for now, but as always, we are full of Ideas and this is a convenient place to put them.
Specs
  • 3x3 m working area
  • movement speed of 1000mm/s
  • Calibrated accuracy and precision of +/- 0.1mm
Axis motors
smeding is going to design and build a proof of concept linear (synchronous) motor for use in the X- and Y-axes. This test rig will be used to determine whether a DIY LSM is at all useful for our application and to finalize the design if we choose to go with the concept. Specifically, this involves figuring out:
  • How the attainable accuracy compares to the wanted specifications
  • How the attainable movement speed compares to the wanted specifications
  • A final design for the drive electronics
  • Coil and armature geometries
  • Rail geometries (magnet size, spacing and orientation pattern and any backing)
  • Optimal control schemes
After this, we'll be ready to construct the three rails (2x X and 1x Y) that make up the bulk of the CNC machine.
