LichtKrant
Revision as of 13:44, 24 February 2020 by Bertrik Sikken (talk | contribs) (TODO)
Project LichtKrant
Controller for 3-colour 80x7 pixel moving LED sign
Last Update 2020-02-24
Status as of 2020/1/13:
  • Reverse engineered it, I know how it works and documented it
  • Software works, allowing arbitrary bitmap graphics to be sent over WiFi. The sign can show 4-bit gradients in both red and green, essentially it now has 8-bit colors instead of 2-bit.
  • The power supply that came with it (5V, 4A) broke down. At full brightness, the display actually uses about 6A, so it seems to be under-dimensioned anyway. A new one costs E20,- (ex shipping)
  • Integration into revspace infrastructure requires more work:
    • write a frame buffer forwarder and fix the linux package manager on the raspberry pi of the 'ledbanner'
    • make it completely "space-approved"
    • I don't feel like doing the above
In other words, learned a lot, but I'm done with it.
Physical dimensions:
  • 80 pixels in about 613 mm wide
  • case is about 675 mm x 109 mm
  • there are two screw holes on the sides, about 660mm apart
  • screw holes are size M6
Hacked it, so now we have the following:
  • reverse engineered the electronics and documented how it works
  • replaced the controller board with an ESP8266, so we can receive image/text updates over the network
  • implemented more colour depth, so we can display gradient bitmaps (not just red/green/orange but any color in between)
  • wrote software for this and published it
Reverse engineering
lichtkrantconnector
Processor board
It takes 5V as input.
LED board
How does it work
*  J1.1: IC2.A1 -> IC2.B1 -> via ... -> shift clock
*  J1.2: GND
*  J1.3: IC2.A2 -> IC2.B2 -> via ... -> latch clock
*                      IC1.B2 -> IC1.A2 -> U11.RCLK
*                      IC1.B5 -> IC1.A5 -> U1.RCLK
*  J1.4: GND
*  J1.5: IC1.B3 -> IC1.A3 -> U11.SER -> data pin for upper shift register (green)
*  J1.6: GND
*  J1.7: IC1.B4 -> IC1.A4 -> U1.SER -> data pin for lower shift register (red)
*  J1.8: GND
*  J1.9: IC2.A7 -> IC2.B7 -> via ... -> row enable
         IC4.1A -> IC4.1Y -> IC3.G2B
* J1.10: VCC
* J1.12: VCC
* J1.14: VCC
* J1.16: J4 (IR receiver)
* J1.17: IC2.A6 -> IC2.B6 -> IC3.G2A -> frame enable, appears to have a pull-up already, so can be left unconnected
* J1.18: ???
* J1.19: ???
  • columns
  • rows
  • other
    • 5V signals
    • GND signals
Levels on the bus are 5V.
Theory of operation:
  • next row
Timing
Columns:
Power consumption
It appears that J1.17 is used by the original control board to set the global brightness.
  • all LEDs off, about 0.1 A (ESP8266 only?)
  • all red LEDs on, about 3.9 A
  • all green LEDs on, about 3.6 A
  • all LEDs (red + green) on, about 5.8 A
  • some text in red on the display, about 1.5A
Hardware modifications
Wemos D1 mini as sign controller
  • soldered a power connector on the center of the display PCB, on the footprint that was already present, 5V is supplied there (up to 6 Amps!)
  • removed the controller board
  • added a Wemos D1 mini board, pinout:
Connections
J1 connector Wemos D1 mini Remark
J1.1 D8 Column data shift
J1.3 D7 Column data latch
J1.5 D6 Green data
J1.7 D5 Red data
J1.8 G Ground
J1.9 D4 Row enable
J1.10 5V 5V from LED board to Wemos D1 mini
J1.11 D3 Row select bit 0
J1.13 D2 Row select bit 1
J1.15 D1 Row select bit 2
 sudo apt install python3-pip
 sudo pip3 install platformio
Driving the pixels
Variable pixel brightness
Variable pixel is implemented using a kind of temporal dithering that flashes the pixels on/off:
  • At each frame start, for each pixel, we add the brightness value from the frame buffer to the brightness count (e.g. 0-255). If the addition results in an overflow, the pixel is lit on the display, otherwise it is dimmed. For example, adding a brightness value of 128 causes the addition to overflow every other time, causing a 50%/50% duty cycle at half the frame frequency.
  • The above is implemented for the red and green pixels separately.
RAW RGB interface
RAW RGB frames (80x8x3 bytes) can be sent over TCP to port 1234. The blue (B) channel is ignored, as is the lowest line of the 80x8 raw RGB frame.
 convert -size 80x10 -crop 80x8+0+2 -font 8-BIT\ WONDER.TTF -pointsize 9 -fill red -background black caption:"AweSome" -depth 8 rgb:- |netcat esp-ledsign.local 1234
 convert metaballs.gif rgb:- |netcat -q0 esp-ledsign.local 1234
Command interpreter
This display could be used as a kind of mirror of the main LED banner, except with no blue color component and 80x7 LEDs instead of 80x8. For example, we could put it up at the kitchen and get notified of people opening doors, doorbell, etc.
Requirements
  • No dodgy power supply, that might catch fire, pose an electrical hazard, or fail in some other unsafe way
  • Don't put it in the lounge, we'd like to keep the lounge clear of attention-grabbing / flashing stuff. The kitchen would be fine.
  • Make it electrically safe, for example a "cage" style power supply should be contained
TODO
List of things to do:
  1. mount the thing in the *kitchen*:
    1. consult with revspace participants about a suitable location, suggested place is somewhere close to the patch cabinet (easier cable management)
    2. need mounting materials, do we have them? do we need to buy them? -> added some pieces of metal to the sides
    3. physical act of fixing it to something, make sure it can't just drop and injure people, damage the wall, etc.
  2. fix software things on the ledbanner pi, to allow forwarding image data to the led sign:
    1. fix fedora repository setup (currently broken), so we can install avahi (for example) and the led sign can be addressed by its mDNS network name, "esp-ledsign.local"
    2. write software *on the ledbanner pi* so raw RGB image frames can be forwarded to the led sign (over TCP/IP) too. Initially I (bertrik) can write software that only shows MQTT notifications as text.
  3. ensure a good enough WiFi connection: I (bertrik) ordered & received a couple of wemos d1 pro minis with an external antenna (in my SAMLA).
    1. mount the ESP8266 inside the casing, making sure the wifi antenna is clear and the d1 mini does not short-circuit
Possibly useful other info:
