TMC2130
Project TMC2130 | |
Guide: Connecting TMC2130 and ESP8266 | |
Status | Completed |
Contact | Sttc |
Last Update | 2020-02-15 |
Status as of 2020/1/15:
- Completed
TMC2130 is utilized for driving a bi-polar step motor in this example.
TMC2130 is a driver module with many functions. This guide explains how to connect TMC2130 directly with ESP8266 via SPI without a motherboard (e.g. MKS Gen L, RAMPS, Einsy Rambo etc.).
Used components:
- TMC2130
Manufacturer: Big Tree Tech
https://www.aliexpress.com/item/32975341864.html?spm=a2g0s.9042311.0.0.5d3e4c4d6bMkco
https://www.trinamic.com/products/integrated-circuits/details/tmc2130/
https://www.dropbox.com/s/xwongsgvshapqaj/TMC2130-V2.0%20spi%20firmware.docx?spm=a2g0o.detail.1000023.19.4fc612156plDrp&dl=0
https://github.com/bigtreetech/BIGTREETECH-TMC2130-V3.0?spm=a2g0o.detail.1000023.18.4fc612156plDrp&file=BIGTREETECH-TMC2130-V3.0
- ESP8266:
LoLin NodeMCU V3 4MB flash ESP8266 12E
More info on ESP8266: https://randomnerdtutorials.com/esp8266-pinout-reference-gpios/
Wiring
TMC2130 board must be modified for SPI communication mode according to manufacturer's instructions
A capacitor in between Vmotor and GND is recommended (here 220µF was used)
Table: Connecting pins between TMC2130 and ESP8266
TMC2130 <-- | --> ESP8266 |
GND | GND |
VIO | 3V |
OA2 | MOTOR-A2 (not on ESP8266) |
OA1 | MOTOR-A1 (not on ESP8266) |
OB1 | MOTOR-B1 (not on ESP8266) |
OB2 | MOTOR-B2 (not on ESP8266) |
GND | GND |
VM | Vmotor (+8V) (not on ESP8266) |
DIR | D2 (GPIO4) |
STEP | D3 (GPIO0) |
NC(not connected) | - |
SD0 | D6 (GPIO12) |
CSN | D8 (GPIO15) |
SCK | D5 (GPIO14) |
SDI | D7 (GPIO13) |
EN | D1 (GPIO5) |
Code
Required libraries:
- TMC2130Stepper
/** * Author Teemu Mäntykallio * Modified by Sttc * Initializes the library and turns the motor in alternating directions. */ // ESP8266 #define EN_PIN 5 // D1 #define DIR_PIN 4 // D2 #define STEP_PIN 0 // D3 #define CS_PIN 15 // D8 #define MOSI_PIN 13 // D7 #define MISO_PIN 12 // D6 #define SCK_PIN 14 // D5 bool dir = true; #include <TMC2130Stepper.h> TMC2130Stepper driver = TMC2130Stepper(EN_PIN, DIR_PIN, STEP_PIN, CS_PIN, MOSI_PIN, MISO_PIN, SCK_PIN); void setup() { Serial.begin(115200); while(!Serial); Serial.println("Start..."); driver.begin(); // Initiate pins and registeries driver.rms_current(600); // Set stepper current to 600mA. The command is the same as command TMC2130.setCurrent(600, 0.11, 0.5); driver.stealthChop(1); // Enable extremely quiet stepping driver.microsteps(0); //Serial.println(driver.microsteps()); // shows microsteps setting digitalWrite(EN_PIN, LOW); //Serial.print("DRV_STATUS=0b"); //Serial.println(driver.DRV_STATUS(), BIN); } void loop() { digitalWrite(STEP_PIN, HIGH); //delayMicroseconds(10); delay(50); digitalWrite(STEP_PIN, LOW); //delayMicroseconds(10); delay(50); uint32_t ms = millis(); static uint32_t last_time = 0; if ((ms - last_time) > 3000) { if (dir) { //Serial.println("Dir -> 0"); driver.shaft_dir(0); } else { //Serial.println("Dir -> 1"); driver.shaft_dir(1); } dir = !dir; last_time = ms; } }
Remarks
- ESP8266 configuration on Arduino IDE:
