MCP23017
Versie door Sttc (overleg | bijdragen) op 15 feb 2020 om 17:16 (Code)
Project MCP23017
Guide: Connecting MCP23017 to ESP8266
Contact sttc
Last Update 2020-02-15
Status as of 2020/1/13:
  • Completed
MCP23017 is a GPIO expander that runs on I2C. This page forms wiring and communication guide for MCP23017 on ESP8266.
Used components:
  • MCP23017
MCP23017 I2C Interface 16bit I/O Extension Module Pin Board IIC to GIPO Converter https://www.aliexpress.com/item/32883688022.html?spm=a2g0s.9042311.0.0.5d3e4c4d6bMkco
  • ESP8266:
LiLon NodeMCU V3 4MB flash ESP8266 12E More info on ESP8266: https://randomnerdtutorials.com/esp8266-pinout-reference-gpios/
Wiring
Setting up ESP8266 for I2C pins is not necessary in this code. SCL and SDA pins as below:
Pin on MCP23017 ESP8266
GND GND
VCC 3V
SCL D1 (GPIO5)
SDA D2 (GPIO4)
Code
Required libraries:
  • Wire
  • Adafruit_MCP23017
// MCP23017 Example: Slow key press reaction.
// Toggle LEDs and detect keypress.
// Example code showing slow reaction of 'button'
// LED to keypress. Leading into why interrupts
// are useful (See next example).
// Copyright : John Main
// Free for non commercial use.
#include <Wire.h>
#include <Adafruit_MCP23017.h>
#define MCP_LED1 7
#define MCP_INPUTPIN 8
#define MCP_LEDTOG1 11
Adafruit_MCP23017 mcp;
void setup() {
  mcp.begin();      // Default device address 0
  mcp.pinMode(MCP_LEDTOG1, OUTPUT);  // LED for blinking
  mcp.pinMode(MCP_LED1, OUTPUT);     // LED output for button
  mcp.digitalWrite(MCP_LED1, HIGH);  // default > LED turn on
  mcp.pinMode(MCP_INPUTPIN,INPUT);   // Button i/p to GND
  mcp.pullUp(MCP_INPUTPIN,HIGH);     // Puled high to ~100k
void loop() {
  // blinking led
  delay(300);
  mcp.digitalWrite(MCP_LEDTOG1, HIGH);
  delay(300);
  mcp.digitalWrite(MCP_LEDTOG1, LOW);
  // Transfer input pin state to LED1
  if (mcp.digitalRead(MCP_INPUTPIN)) {
     mcp.digitalWrite(MCP_LED1,HIGH);
  } else {
     mcp.digitalWrite(MCP_LED1,LOW);
MCP21017 GPIO
Number in IDE =
mcp.pinMode(Number in IDE, OUTPUT);
MCP21017 Number in IDE
PA0 0
PA1 1
PA2 2
PA3 3
PA4 4
PA5 5
PA6 6
PA7 7
PB0 8
PB1 9
PB2 10
PB3 11
PB4 12
PB5 13
PB6 14
PB7 15
Remarks
Pins of VCC,GND,SCL,SDA,RT,ITA,ITB line do not fit to the board together with GPIO pins (PA7, PA6...) > (Do not solder VCC... line pins)
