MCP23017
Project MCP23017 | |
Guide: Connecting MCP23017 to ESP8266 | |
Status | Completed |
Contact | sttc |
Last Update | 2020-02-15 |
Status as of 2020/1/13:
- Completed
MCP23017 is a GPIO expander that runs on I2C. This page forms wiring and communication guide for MCP23017 on ESP8266.
Used components:
- MCP23017
MCP23017 I2C Interface 16bit I/O Extension Module Pin Board IIC to GIPO Converter https://www.aliexpress.com/item/32883688022.html?spm=a2g0s.9042311.0.0.5d3e4c4d6bMkco
- ESP8266:
LiLon NodeMCU V3 4MB flash ESP8266 12E More info on ESP8266: https://randomnerdtutorials.com/esp8266-pinout-reference-gpios/
Wiring
Setting up ESP8266 for I2C pins is not necessary in this code. SCL and SDA pins as below:
Pin on MCP23017 | ESP8266 |
GND | GND |
VCC | 3V |
SCL | D1 (GPIO5) |
SDA | D2 (GPIO4) |
Code
Required libraries:
- Wire
- Adafruit_MCP23017.h>
// MCP23017 Example: Slow key press reaction. // // Toggle LEDs and detect keypress. // // Example code showing slow reaction of 'button' // LED to keypress. Leading into why interrupts // are useful (See next example). // // Copyright : John Main // Free for non commercial use. #include <Wire.h> #include <Adafruit_MCP23017.h> #define MCP_LED1 7 #define MCP_INPUTPIN 8 #define MCP_LEDTOG1 11 Adafruit_MCP23017 mcp; void setup() { mcp.begin(); // Default device address 0 mcp.pinMode(MCP_LEDTOG1, OUTPUT); // LED for blinking mcp.pinMode(MCP_LED1, OUTPUT); // LED output for button mcp.digitalWrite(MCP_LED1, HIGH); // default > LED turn on mcp.pinMode(MCP_INPUTPIN,INPUT); // Button i/p to GND mcp.pullUp(MCP_INPUTPIN,HIGH); // Puled high to ~100k } void loop() { // blinking led delay(300); mcp.digitalWrite(MCP_LEDTOG1, HIGH); delay(300); mcp.digitalWrite(MCP_LEDTOG1, LOW); // Transfer input pin state to LED1 if (mcp.digitalRead(MCP_INPUTPIN)) { mcp.digitalWrite(MCP_LED1,HIGH); } else { mcp.digitalWrite(MCP_LED1,LOW); } }
MCP21017 GPIO
Number in IDE =
mcp.pinMode(Number in IDE, OUTPUT);
MCP21017 | Number in IDE |
PA0 | 0 |
PA1 | 1 |
PA2 | 2 |
PA3 | 3 |
PA4 | 4 |
PA5 | 5 |
PA6 | 6 |
PA7 | 7 |
PB0 | 8 |
PB1 | 9 |
PB2 | 10 |
PB3 | 11 |
PB4 | 12 |
PB5 | 13 |
PB6 | 14 |
PB7 | 15 |
Remarks
Pins of VCC,GND,SCL,SDA,RT,ITA,ITB line do not fit to the board together with GPIO pins (PA7, PA6...) > (Do not solder VCC... line pins)
