LichtKrant
Revision as of 09:32, 15 December 2019 by Bertrik Sikken (talk | contribs)
Project LichtKrant
350px
Een korte inleidende tekst
Status Initializing
Last Update 2019-12-15
Found this lichtkrant on the revspace free stuff table.
lichtkrantconnector
Processor board
It takes 5V as input.
Connector pinout J1
  • 1: pin A8 of IC6 (245)
  • 2: GND?
  • 3: pin A1
  • 4: GND
  • 5: pin A2
  • 6:
  • 7: pin A3
  • 8:
  • 9: pin A4
  • 10:
  • 11: pin A5
  • 12:
  • 13: pin A6
  • 14:
  • 15: pin A7
  • 16:
  • 17: pin A8
  • 18:
  • 19: 5V
  • 20: 5V
So it basically looks like a 9 bit bus. Levels on the bus are 5V (so can we drive it with an ESP?)
LED board
The LED board contains the actual display blocks.
It has a text on it: HXBI80070509.PCN, date 2007-12-28
It consists of 16 blocks of 5x7 LEDs. Each LED has a red sub-pixel and a green sub-pixel.
The are already electronics on it, consisting mostly of 595 chips (serial shift registers).
Possibly useful other info:
