LichtKrant
| Project LichtKrant | |
| 350px | |
| Een korte inleidende tekst | |
| Status | Initializing |
| Last Update | 2019-12-15 |
Found this lichtkrant on the revspace free stuff table.
Processor board
It takes 5V as input.
Connector pinout J1
- 1: pin A8 of IC6 (245)
- 2: GND?
- 3: pin A1
- 4: GND
- 5: pin A2
- 6:
- 7: pin A3
- 8:
- 9: pin A4
- 10:
- 11: pin A5
- 12:
- 13: pin A6
- 14:
- 15: pin A7
- 16:
- 17: pin A8
- 18:
- 19: 5V
- 20: 5V
So it basically looks like a 9 bit bus. Levels on the bus are 5V (so can we drive it with an ESP?)
LED board
The LED board contains the actual display blocks.
It has a text on it: HXBI80070509.PCN, date 2007-12-28
It consists of 16 blocks of 5x7 LEDs. Each LED has a red sub-pixel and a green sub-pixel.
The are already electronics on it, consisting mostly of 595 chips (serial shift registers).
