StofAnanas
Project StofAnanas
Status Initializing
Last Update 2019-06-16
The idea
Show current airborne particulate matter concentration using a LED light in a lamp, inspired by http://stoflamp.nl The data that the LED colour is based on is simply retrieved over WiFi from the luftdaten website.
This lamp is a plastic pine apple ("ananas"), bought at the "Action" store.
Concepts/ideas:
  • The lamp shows particulate matter concentration as a colour, e.g. soft/positive colours for low concentration and hard/bright colour for high concentration
  • The lamp "breathes" by varying the intensity over time, e.g. a cycle of 10 seconds where the light dims a bit and brightens a bit. Perhaps we can increase the breathing rate as well for higher PM.
  • The lamp retrieves the PM value over wifi from the the luftdaten website
Nice to have:
  • Automatic determination of location by means of wifi location
  • Remote control over IR
pinout
The lamp is controlled by an ESP8266, a Wemos D1 mini board. The LEDs used has a built-in PL9823 controller.
Connections:
  • LED Din to Wemos D1 mini pin D4
  • LED Gnd to Wemos D1 mini pin GND
  • LED Vdd to Wemos D1 mini pin 5V
Software is available on github.
Luftdaten interface
The current measurement value of a particular sensor can be retrieved over a REST interface, using URL
For example:
A HTTP GET results in a list of JSON structure like this:
    "id": 3941048759,
    "location": {
      "altitude": "0.6",
      "id": 6186,
      "indoor": 0,
      "country": "NL",
      "exact_location": 0,
      "longitude": "4.692",
      "latitude": "52.022"
    "timestamp": "2019-06-16 09:46:03",
    "sampling_rate": null,
    "sensordatavalues": [
        "id": 8353891652,
        "value_type": "P0",
        "value": "10.60"
        "id": 8353891653,
        "value_type": "P1",
        "value": "17.80"
        "id": 8353891654,
        "value_type": "P2",
        "value": "15.60"
    "sensor": {
      "id": 12246,
      "sensor_type": {
        "name": "PMS7003",
        "id": 22,
        "manufacturer": "Plantower"
      "pin": "1"
Arduino libraries
Libraries:
  • WiFiManager is used to manage WiFi connection to the local AP
  • FastLED is used to control the LED
  • ArduinoJSON for the parsing the luftdaten response
