Stofradar
Project Stofradar
Visualizing atmospheric particulate matter concentrations on a map
Last Update 2019-01-01
This page is about creating a 'stofradar' image of atmospheric particulate matter concentrations based on the raw data measured by the luftdaten.info network, see www.stofradar.nl.
See also my DustSensor page.
The website luftdaten.info is an initiative to allow citizens to participate in measuring atmospheric particulate matter concentration using an inexpensive and easy to build sensor. They collect this data, calculate 5 minute and daily averages and publish it again as open data. The total number of sensors is > 5000 worldwide, most of them in Germany, Bulgaria, Belgium, Austria, Sweden. The Netherlands has about 100 sensors.
Future activities:
  • get an OSM background map, once their export functionality works again, https://www.openstreetmap.org/export still broken .... :(
  • fix fine alignment between map and dust overlay
  • also create a map of a larger area, including germany (it has a lot of data points)
Visualisation
Background map
Pages to investigate:
What I need/want is to be able to specify the 'bounding box' and use a equirectangular projection , so I can easily map a pixel back to a latitude/longitude.
Interpolation
To calculate the distance2, I use a very simple approximation:
  • determine the difference in longitude and latitude
  • apply an 'aspect ratio' factor of cos(latitude) to the longitude difference. I use the latitude of the approximate middle of the netherlands (52.2 lat, 5.3 lon) to calculate this aspect ratio factor.
  • distance2 = (difference latitude)2 + (difference longitude)2
A better way would be to use the 'great-circle-distance' and possibly even account for the fact that the earth is not perfectly spherical, but I like to start simple and this makes the calculation a lot faster.
PM10 values higher than 500 ug/m3 are simply ignored in the software.
Colour range
The colours I'm using (a kind of inverted spectral range from blue to red):
  • 0 ug/m3: fully transparent white (#FFFFFF)
  • 25 ug/m3: semi-transparent cyan (#00FFFF)
  • 50 ug/m3: semi-transparent yellow (#FFFF00). This is the threshold for the maximum daily average in the Netherlands.
  • 100 ug/m3: semi-transparent red (#FF0000)
  • 200 ug/m3 and higher: semi-transparent purple (#FF00FF)
This scale is approximately logarithmic, with each step being twice as big as the previous one.
Correction for high humidity
Humidity generally seems to cause an overestimation of PM measurements for measurements done with a "particle counting" type of PM sensor. The effect become really significant above approximately 70% humidity.
An interesting idea is to try to compensate for this effect, since the luftdaten sensor has an onboard humidity-sensor. Some papers/links about this:
  • it combines formulas and coefficients from different sources where relative humidity has different units. One paper seems to use an RH-value from 0 to 100, while another uses a kind of normalized relatively humidity (from 0 to 1). You cannot just use the same coefficients if the unit is different.
Compositing
I use imagemagick for this, for example:
 composite -compose over -geometry 600x800 20180605_210100.json.png netherlands.png output.png
where netherlands.png is an 600x800 opaque black-and-white image of the map of the netherlands and 20180605_210100.json.png is an 60x80 image of dust concentrations with an alpha channel
Animation
The idea of animation is to combine several 5-minute images into a movie.
There are several options and file formats to choose from:
  • GIF appears way too big, resulting in files of about 40 MB for 288 frames.
  • APNG is only slighty smaller at about 37 MB.
  • the webm format seems more suited, can be less than 1MB (lossy, VP9).
Example conversion command for webm:
 cat ~/luftdatenmapper/tmp/netherlands/*.png |ffmpeg -f image2pipe -r 12 -i - -b:v 200k netherlands.webm
This results in an output file of about 650 kB.
