| Project Radio controlled Bicycle back light | |
| A battery powered bicycle back light that can be used to find your bike. | |
| Contact | Mahjongg |
| Last Update | 2018-04-09 |
I engineered a solution around a 315MHz receiver.
This is the (fully updated to rev 2.4) schematic.
this is the component placement drawing as a .PDF : Bestand:Componenten opstelling rf backlight rev 2,2.pdf
this is a 3D rendering of the PCB with the component placement and layout of version 2.2.
Here are pictures of the PCB, left topside, right bottom side. Now with silk screen printing, and with the added static cap and SMT coil of version 2.3
6 March, 2018, calculated LC resonance values
Calculated the values for the L and C (C7 or C18 and L3 or L4) of the 315MHz resonance circuit with f= 1/(2 * PI * SQR(L*C)) . Using a trim-cap trimable between 3 and 10pf, (a TZC3R100A110R00 Farnell code 2456140 ) I estimate the average capacity at 6.5pf, meaning the inductance should be about 39nH (see resonance calculator here: http://www.1728.org/resfreq.htm ). I now also found a suitable 39nH coil, (Coilcraft 1812SMS-39NJLC, farnell code 2287131) so I have added a SMT footprint for it. I will also add a footprint for a 0603 cap underneath the trimcap, so I can replace the trim-cap with a fixed one if I want to use a trimable coil instead of a trimable cap.
The new schematic is Bestand:Rfachterlicht rev 2.3.pdf (revision 2.4). The PCB above now shows version 2.4.
April 4, 2018, uploading the production files to Eurocircuits failed
Unfortunately the PCB did not check out when we tried to upload it at Eurocircuits (the PCB manufacturer) Due to some last minute changes. One trace was not connected to the non-trimmable coil Pad, and there were a few via's that did not have enough metal round their holes. I also see a via that doesn't seem to serve a purpose. Initially I thought I could do the repairs on Sunday the 8th, but for some reason that weekend my Asthma became so bad that had no energy at all so I had to stay indoors, perhaps as a result of pollen combined with air pollution. I now hope to do the repairs next Tuesday the 10th.
