Project Radio controlled Bicycle back light | |
A battery powered bicycle back light that can be used to find your bike. | |
Status | Initializing |
Contact | Mahjongg |
Last Update | 2018-03-07 |
I engineered a solution around a 315MHz receiver.
This is the (updated to rev 2.1) schematic.
File:RF Achterlicht rev2.1.pdf
Also updated the schematic: File:Rf achterlicht rev 2,2.pdf this is the component placement drawing as a .PDF : File:Componenten opstelling rf backlight rev 2,2.pdf
this is a 3D rendering of the PCB with the latest component placement, and now also layout.
Here are pictures of the PCB, left topside, right bottom side. Now with silk screen printing, and with the added static cap and SMT coil of version 2.3
6 March, 2018, calculated LC resonance values
Calculated the values for the L and C of the 315MHz resonance circuit with f= 1/(2 * PI * SQR(L*C)) . Using a trim-cap trimable between 3 and 10pf, I estimate the average capacity at 6.5pf, meaning the inductance should be about 39nH (see resonance calculator here: http://www.1728.org/resfreq.htm ). I now found a suitable 39nH coil, (Coilcraft 1812SMS-39N_L_) so I can add a footprint for it. I will also add a footprint for a 0603 cap, so I can replace the trim-cap with a fixed one if I want to use a trimable coil instead of a trimable cap.
The new schematic is File:Rfachterlicht rev 2.3.pdf (revision 2.3). Will check in PCB tomorrow.
