Luteijn/Vortex
Project "Vortex":
| Project Luteijn/Vortex | |
| Contact | Luteijn |
| Last Update | 2018-02-16 |
What's connected to the pins
| 0 | Serial RX (input) |
| 1 | Serial TX (output) |
| 2 | Encoder Wheel (External Interrupt 0) (input) |
| 3 | Encoder Wheel (External Interrupt 1) (input) |
| 4 | Unknown, seems to be pulled high when used as input. Found it too hard to trace on the board. |
| 5 | Motor 0 Speed (PWM) (output) |
| 6 | Motor 1 Speed (PWM) (output) |
| 7 | IR decoder/detector (input) |
| 8 | IR led Left (output) |
| 9 | Motor 0 direction (H=forwards,L=reverse) (output) |
| 10 | Motor 1 direction (output) |
| 11 | MP3-player TX (output) |
| 12 | IR led Right (output) |
| 13 | GRB LED chain around body (output) |
| A0 | grayscale 4 'D' (input) |
| A1 | grayscale 3 'C' (input) |
| A2 | grayscale 2 'B' (input) |
| A3 | grayscale 1 'A' (input) |
| A4 | SDA (i2c) |
| A5 | SCL (i2c) |
| A6 | grayscale 5 'E' (input) |
| A7 | grayscale 6 'F' (input) |
i2c bus + Vcc & Gnd should be available at 4 pin rear expansion port too - need to find a suitable connector for it..
http://www.hobbytronics.co.uk/arduino-atmega328-pinout Useful diagrams to map pins to package
Dumping original firmware
Although you can/should be able to reflash Vortex with the App, might as well make a backup of the orignal:
avrdude -c arduino -p m328p -P /dev/ttyACM0 -U flash:r:"Vortex.hex":i
This can be uploaded again with:
avrdude -c arduino -p m328p -P /dev/ttyACM0 -U flash:w:"Vortex.hex":i
(The app might also be initializing other things, but this seems to work)
Your own sketches can be uploaded with
arduino --upload MySketch.ino
But using avrdude to upload the .hex file is a bit quicker.
Motor Control
int E1 = 5;
int M1 = 9;
int E2 = 6;
int M2 = 10;
void setup()
pinMode(M2, OUTPUT);
void loop()
int value;
for(value = 0 ; value <= 255; value+=5) //foreward
digitalWrite(M1,HIGH);
digitalWrite(M2, HIGH);
analogWrite(E1, value); //PWM Speed control
analogWrite(E2, value); //PWM Speed Control
delay(30);
for(value = 0 ; value <= 255; value+=5) //backward
digitalWrite(M1, LOW);
digitalWrite(M2, LOW);
delay(30);
Encoders
long leftPul,rightPul;
void leftCallBack(){
leftPul++;
void rightCallBack(){
rightPul++;
void initDdevice(){
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
noInterrupts();
interrupts();
void motorDebug(){
digitalWrite(5,HIGH);
digitalWrite(6,HIGH);
digitalWrite(9,HIGH);
digitalWrite(10,HIGH);
void printPul(){
Serial.print(leftPul);
Serial.print(" ");
Serial.println(rightPul);
leftPul = 0;
rightPul = 0;
void setup() {
initDdevice();
Serial.begin(9600);
motorDebug();
void loop() {
printPul();
delay(500);
Analogue Inputs
2 (a2) 3 (a1)
1 (a3) 4 (a0)
5 (a6) 6 (a7)
void setup(void){
Serial.begin(9600);
int analogBuf[6] = {'\0'};
void loop(void){
analogBuf[0] = analogRead(3);
analogBuf[1] = analogRead(2);
analogBuf[2] = analogRead(1);
analogBuf[3] = analogRead(0);
analogBuf[4] = analogRead(6);
analogBuf[5] = analogRead(7);
for(int i=0;i<6;i++){
Serial.print(i+1);
Serial.print(": ");
Serial.print(analogBuf[i]);
Serial.print(" ");
Serial.println();
delay(500);
LEDs
FastLED.addLeds<WS2811, DATA_PIN, GRB>(leds, NUM_LEDS);
IR obstacle detector
Seems to be somewhat flaky. Needs a bit more work to figure out. Also, the IR sensor is useful to read IR remote controllers or beacons. This receiver seems to work at 38kHz, but probabbly also reacts to 36-40kHz. Remote controllers often work at 36kHz. Note that 2x 8µs delay doesn't give you 38kHz, but the digitalWrite itself also induces quite some delay (3-6µs), so seems this is bringing the total period up to around the 26.something µs we'd expect.
#define NUM_LEDS 12
// Data pin that led data will be written out over
#define DATA_PIN 13
CRGB leds[NUM_LEDS];
#define IR_IN 7//IR receiver pin
#define L_IR 8 //left ir transmitter pin
int count;
int i;
for(i=0;i<24;i++){
digitalWrite(L_IR,LOW);
delayMicroseconds(8);
digitalWrite(L_IR,HIGH);
int i;
for(i=0;i<24;i++){
digitalWrite(R_IR,LOW);
digitalWrite(R_IR,HIGH);
PCICR |= 1 << PCIE2;
count++;
void obstacleAvoidance(void){
char i;
count=0;
leds[5] = CRGB::Green;
FastLED.show();
for(i=0;i<20;i++){ //left transmitter sends 20 pulses
leftSend38KHZ();
delayMicroseconds(600);
leds[5] = CRGB::White;
FastLED.show();
Serial.println("Left");
delay(100);
count=0;
leds[3] = CRGB::Green;
FastLED.show();
rightSend38KHZ();
leds[3] = CRGB::White;
FastLED.show();
Serial.println("Right");
delay(100);
delay(600);
void setup(void){
delay(2000);
Serial.begin(9600);
leds[4] = CRGB::Blue;
FastLED.show();
delay(2000);
leds[4] = CRGB::Purple;
FastLED.show();
noInterrupts();
pcint0Init();
interrupts(); //enable the interrupt
void loop(void){
obstacleAvoidance();
IRreceiver
#include "IRremote.h"
IRrecv irrecv(IR_IN);
decode_results results;
void setup(void){
Serial.begin(9600);
irrecv.enableIRIn(); // Start the receiver
void loop(void){
if (irrecv.decode(&results)) {
irrecv.resume(); // Receive the next value
The receiver is mounted on the front, bottom. So not right between the eyes, although a spot seems to be prepared for it there too.
The tables at Luteijn/IRRemotes might be useful when creating a sketch that is to be controlled over IR.
Here's an example of a simple driving sketch controlled via my RTeL-Cheapo remote.
#define IR_IN (7)//IR receiver pin
#define E1 (5)
#define E2 (6)
#define M1 (9)
#define M2 (10)
// MSB is direction, 0xff full forward, 0x00 full backwards
uint8_t Left=128; // 0x80 : forward, speed 0
uint8_t Right=128; // 0x80 : forward, speed 0
void setup(void){
delay(2000); // grace period
Serial.begin(9600);
Engine(Left,Right);
void Engine(uint8_t Left, uint8_t Right) {
uint8_t D1=Left&0x80;
uint8_t D2=Right&0x80;
uint8_t S1=D1?Left&0x7f:0x7f-(Left&0x7f);
uint8_t S2=D2?Right&0x7f:0x7f-(Right&0x7f);
Serial.print(Left,HEX);
Serial.print("<-L R->");
Serial.println(Right,HEX);
digitalWrite(M1,D1);
analogWrite(E1,S1<<1);
digitalWrite(M2,D2);
analogWrite(E2,S2<<1);
uint32_t last;
void loop(void){
uint32_t code;
if (code=irrecv.decode(&results)) {
code=results.value;
Serial.print("Got IR:");
Serial.println(code,HEX);
if (code==0xFFFFFFFF) {code=last;}; // repeated press
if (code==0xFFB24D) { // power = full stop
Left=128;
Right=128;
} else if (code==0xFF02FD) { // full screen both go towards full stop
if (Left<128) Left++; else Left--;
if (Right<128) Right++; else Right--;
} else if (code==0xFFA05F) { // ch+ increase both towards full ahead
if (Left<255) Left++;
if (Right<255) Right++;
} else if (code==0xFF40BF) { // ch- decrease both towards full reverse
if (Left>0) Left--;
if (Right>0) Right--;
} else if (code==0xFF50AF) { // vol- left towards full stop
} else if (code==0xFF32CD) { // record increase left towards full ahead
} else if (code==0xFF48B7) { // 0 decrease left towards full reverse
if (Left>0) Left--;
} else if (code==0xFF7887) { // vol+ right towards full stop
} else if (code==0xFF30CF) { // time shift increase right towards full ahead
} else if (code==0xFF38C7) { // recall decrease right towards full reverse
} else {
// ignore unknown codes
last=code;
Engine(Left,Right);
It would be better to use a stronger remote for this as it's hard to successfully control the robot when it's facing away from you. Also, the speed ramp up/down is a bit slow, and should probably take bigger steps than one at a time.
Left as an exercise to the reader: add controls to spin in place left/right, using interrupts of wheel encoders to rotate 45/90 etc. degrees, boundary detection with analogue sensors, object detection with IR (careful not to make control harder). Switch to a bluetooth remote controller once figured out the possibilities of bluetooth better?
MP3-player
#define MP3_VOLUME 0x10
#define TX 11
#define RX 4 // ?? was 2 in example I found, but that is unlikely
#include <SoftwareSerial.h>
void setup()
delay(1000);
mp3Init();
mp3setVolume(30);//0~30
void loop()
mp3player(1);
delay(2000);
mp3stop();
delay(1000);
void mp3Init()
mySerial.begin (9600);
void mp3setVolume(byte vol)
mySerial.write(buffer, 8);
delay(20);
void mp3player(byte data)
delay(20);
void mp3stop()
https://www.dfrobot.com/product-1121.html , documented at https://www.dfrobot.com/wiki/index.php/DFPlayer_Mini_SKU:DFR0299 is a mini-MP3 player from DFRobot. It is controllable over serial, and might be the same one as used in the Vortex. Would be good to figure out if the 'busy' signal and/or the serial TX are connected back to the arduino somewhere in that case. Player could also be a variant but the magic numbers more or less match (although the stop command 0x16 is not in the table.
The MP3-chip inside Vortex has Part# YX6100-24SS. Seems to be part of a family of serial MP3-players made by "广州悦欣电子科技有限公司" --> "Guangzhou Yue Xin Electronic Technology Co., Ltd." - website http://www.yx080.com/mp3xinpian/53-15.html has a download link on this yx6100 page but it seems to just refer us to the 5200 application Manual V1.8, which appears to be mostly compatible. The command table for the chip does include a 0x16 stop command.
Also the datasheet mentions the chip can play both MP3 and WAV. YX5300-24SS is a similar part, datasheet at https://xp-dev.com/trac/arduino_antonio/export/280/arduino_antonio/trunk/EnterpriseBase/Serial%20MP3%20Player/About%20the%20Chip%20-%20YX5300/YX5300-24SS%20Datasheet%20V1.0.pdf The command table for that chip does include a 0x16 stop command.
| $S | Start byte 0x7e | Each command begins with 0x7e ('~') |
| VER | Version information | Version seems to be 0xff from the example |
| Len | the number of bytes | Start, End and Checksum are not counted, |
| CMD | Commands | See command table. |
| Feedback | Command feedback | 1: feedback, 0: no feedback ; need to test what this does, might mean 'echo' |
| Para1 | Parameter 1 | Query high data byte |
| Para2 | Parameter 2 | Query low data byte |
| checksum | Checksum | accumulation and verification, doesn't include start byte. Seems to be 2 bytes from the example given in the docs, but Vortex seems to just not need it put in. example given is 7e ff 06 09 00 00 04 ff dd ef ; The 5200 Datasheet uses the exact same example command, and explains that you should add all the bytes, and then subtract those from 0 to get the checksum. The 5300 Datasheet also mentions "另外用户也可以直接忽视校验,参考我们的5.3.4 章节说明。" so looks like the checksum is optional if you don't care too much about corruption of the occasional command. |
| $O | End byte | End of command is signaled with 0xEF |
| CMD | Function Description | Parameters (16 bit) | compared with YX5300 info |
| 0x01 | Next | ||
| 0x02 | Previous | ||
| 0x03 | Specific track | 0-2999 but example is only using low byte. also track 0 doesn't seem to do anything? | Indicates 1-255 are the valid tracks only. |
| 0x04 | Volume up | ||
| 0x05 | Volume down | ||
| 0x06 | Set Volume | 0-30 (10 is already quite loud!) | |
| 0x07 | Specify EQ(0/1/2/3/4/5/) | Normal/Pop/Rock/Jazz/Classic/Base. | Reserved in the 5300's command list. |
| 0x08 | Specify playback mode (0/1/2/3) | Repeat/folder repeat/single repeat/random | See 3.4.3; this explains the argument is the song to play in a loop - may have been changed for 6100 |
| 0x09 | Select source (0/1/2/3/4) | U/TF/AUX/SLEEP/FLASH | See 3.4.4; specifies 1 as U, 2 as TF, 4 as PC, 5 FLASH and 6 SLEEP |
| 0x0a | Enter into standby - low power loss | Sleep - Low power consumption 10MA (obviously mA or µA, not MA, is meant) | |
| 0x0b | Normal working | Wake up from sleep | |
| 0x0c | reset module | chip reset | |
| 0x0d | Playback | Play - seems to be contrast to suspend/pause | |
| 0x0e | Pause | Suspended | |
| 0x0f | Specify folder to playback | 1~10(need to set by user) | see 3.4.5 - DH: represents the name of the folder, the default support for 99 files, 01 - 99 named DL: represents the track, the default maximum of 255 songs, that is, 0x01 ~ 0xFF |
| 0x10 | Volume adjust set | DH=1:open volume adjust DL: set volume gain 0~31 | not present in command table |
| 0x11 | Repeat play | 1:start repeat play 0: stop play | not present in command table |
| 0x16 | not in the table | example mentions it as a stop command | Stop |
| 0x17 | not in the table | FLASH only, see 3.4.7 (but is in section 3.4.6), select folder to loop. | |
| 0x18 | not in the table | Reserved | |
| 0x19 | not in the table | See 3.4.8 (but is in section 3.4.7), select loop current track mode | |
| 0x21 | not in the table | See 3.4.9 (3.4.8), set DAC to High-Z mode (1) or on (0) so you can use the amp for something else. | |
| 0x22 | not in the table | See 3.4.10 (section 3.4.9 doesn't exist), Set volume and song to play in one command (H:volume L:track) | |
| 0x3C | STAY | Reserved | |
| 0x3D | STAY | Reserved | |
| 0x3E | STAY | Reserved | |
| 0x3F | Send initialization parameters | 0-0x0F (each bit represent one device of the low-four bits) | Seems to be reporting which storage devices are currently online (see section 3.5.1) |
| 0x40 | Returns an error, request retransmission | Probably this is a response to a command meaning Error Encountered. | |
| 0x41 | Answer | Probably this is a response to a query and just means Accepted. | |
| 0x42 | Query Status | See 3.4.10 (actually 3.5.2) - explains that this will return which storage is used and if it's playing, stopped or paused. The storage could also be 'SLEEP' to indicate sleeping? | |
uint16_t sum = 0;
sum += buffer[i];
return -sum;
Eyes
The 'Eyes' are connected over i2c. The daughterboard they are on features an STM8S103K3 (see http://www.st.com/en/microcontrollers/stm8s103-105.html ) and 2x HC595 (shift registers). Besides 35 predefined eye patterns, it is also possible to upload your own eye patterns.
#include <Wire.h>
#define I2C_WRITE 0x00
uint8_t serial=0;
void setup(){
Wire.begin(); // join i2c bus (address optional for master)
defined_eyes(6,1);
delay(2000);
void loop(){
defined_eyes(1,serial);
serial++;
if(serial>=35) serial=0;
delay(250);
Wire.beginTransmission(I2C_LED_ADDRESS << 1 | I2C_WRITE); // transmit to device #4
// (I suppose they mean 0x40, although eyes seem to also respond on 0xC0 which is what is defined above, and 0x20)
Wire.write(serial); //preset eyes 0~34
Wire.endTransmission(); // stop transmitting
void custom_eyes(uint8_t color, uint8_t eyeline[10]){
uint8_t index;
// right eye left eye
//1 2 3 4 5 25 24 23 22 21
//6 7 8 9 10 20 19 18 17 16
//11 12 13 14 15 15 14 13 12 11
//16 17 18 19 20 10 9 8 7 6
//21 22 23 24 25 5 4 3 2 1
Wire.write(0x55); // color 55=custom eyes follow
Wire.write(0xAA); // ?? AA=color followed by 10 bytes, each defining one line
Wire.write(color&0x7); //color 1-B,2-G,4-R of foreground
for (index=0;index<10;index++) {
Wire.write(eyeline[index]);
void example_eyes() {
Wire.write(0x1c);
Wire.write(0x18);
Wire.write(0x10);
Wire.write(0x1f); // top row all 5 bits lit
Wire.write(0x0f); // leds 6,7,8,9 on 10 off
Wire.write(0x07); // 11,12,13 on, 14,15 off
Wire.write(0x03);
Wire.write(0x01);
KITT-scanner / Cylon
This animates the eyes and adds some simple sound effects - currently the eye warble is not synchronized to the eye movement. The IR remote is used to trigger the well-known 'By your command'. For a KITT scanner may want to change to the proper woosh for a KITT, and replace the command sample with something like 'yes, Michael' :)
#include <Wire.h>
#include <IRremote.h>
#define MTX (11)
#define MRX (4)
// Song number for "By your command"-sample
#define BYC (30)
// Song number for Warble
#define Warble (31)
#define IR_IN (7)
#define I2C_LED_ADDRESS 0x80
bool left=1;
SoftwareSerial mp3(MRX,MTX);
short command=0;
uint8_t eyes[10]={0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
void setup(){
mp3Init();
delay(2000);
delay(100);
mp3setVolume(10);//0~255, but 30 is already quite loud!
delay(50);
mp3player(Warble);
delay(50);
mp3repeat(2); // repeat once
delay(50);
mp3player(BYC);
delay(3000);
mp3setVolume(8);//0~255, but 30 is already quite loud!
delay(50);
mp3player(Warble);
delay(50);
mp3repeat(0); // repeat forever
delay(50);
void lscroll_eyes(uint8_t * eyes ){
uint8_t i;
eyes[2]=(uint8_t)(eyes[2]<<1);
eyes[7]=(uint8_t)(eyes[7]<<1);
void rscroll_eyes(uint8_t * eyes ){
uint8_t i;
eyes[2]=(uint8_t)(eyes[2]>>1);
eyes[7]=(uint8_t)(eyes[7]>>1);
uint8_t index;
Wire.beginTransmission(I2C_LED_ADDRESS); // 0x4 preshifted to 0x8 and lsb set to 0 for write
Wire.write(0x55); // register 55=?custom eyes
void loop(){
// 1 2 4 8 10 '20' 10 8 4 2 1
if (left) {lscroll_eyes(eyes);}
else if (!left) {rscroll_eyes(eyes);}
custom_eyes(4,eyes);
if (eyes[7]==0x1) {left=1;}
else if (eyes[2]==0x1) {left=1;}
else if (left && eyes[2]>=0x10) {eyes[2]=0;eyes[7]=0x20;left=0;}
else if (left && eyes[7]>=0x10) {eyes[7]=0;eyes[2]=0x20;left=0;}
if (irrecv.decode(&results)){
if (command) {
command=0;
} else{
command=34; // adjust to match sample length
mp3player(BYC);
delay(50);
irrecv.resume();
} else {
if (command) {
command--;
if (!command){
mp3player(Warble);
delay(50);
} else {
delay(80);
} else {
delay(80);
void mp3Init()
uint8_t buffer[] = {0x7e, 0xff, 0x06, 0x0C, 0x00, 0x00, 0x00, 0xef};
mp3.begin(9600);
delay(100);
mp3.write(buffer, 8);
delay(100);
void mp3repeat(byte data)
uint8_t buffer[] = {0x7e, 0xff, 0x06, 0x08, 0x00, 0x00, data, 0xef};
Conway's Game of Life
2 5x5 fields linked as a torus of 10x5. Change mapping of cells in the edge to make e.g. a front and a back side, or change to 8x8 and add 4 more faces and a bit more mapping to create an LED cube of 6 faces. Simple animation on the 2 eye matrices. This version doesn't actually do something with the remote control, but it was easy to add things like reset board, change color, introduce disturbance etc.
#include <Wire.h>
#define IR_IN (7)
// 5x5 matrix eye
#define CX (5)
#define CY (5)
// edge of 1 cell on each end
#define CXM (7)
#define CYM (7)
#define F (2) // 2 faces have I.
uint8_t eyes[10];
uint8_t board_a[F][CYM][CXM];
uint8_t board_b[F][CYM][CXM];
inline void clear(uint8_t board[][CYM][CXM]) {
uint8_t i,j,k;
for (k=0;k<F;k++) {
for (j=0;j<CYM;j++) {
for (i=0;i<CXM;i++) {
board[k][j][i]=0;
inline uint8_t neighbors(uint8_t s[][CYM][CXM], uint8_t k,uint8_t j,uint8_t i) {
return s[k][j-1][i-1]+s[k][j-1][i]+s[k][j-1][i+1]+s[k][j][i-1]+s[k][j][i+1]+s[k][j+1][i-1]+s[k][j+1][i]+s[k][j+1][i+1];
inline void play(uint8_t s[][CYM][CXM], uint8_t d[][CYM][CXM]) {
uint8_t i,j,k;
// TODO: load edges from right faces hardcoded for 5x5 now
for (i=1;i<=5;i++) {
s[0][0][i]=s[0][5][i];
s[0][6][i]=s[0][1][i];
s[0][i][0]=s[1][i][5];
s[0][i][6]=s[1][i][1];
s[1][0][i]=s[1][5][i];
s[1][6][i]=s[1][1][i];
s[1][i][0]=s[0][i][5];
s[1][i][6]=s[0][i][1];
// corners
s[0][0][0]=s[1][5][5];
s[0][6][0]=s[1][1][5];
s[0][0][6]=s[1][5][1];
s[0][6][6]=s[1][1][1];
s[1][0][0]=s[0][5][5];
s[1][6][0]=s[0][1][5];
s[1][0][6]=s[0][5][1];
s[1][6][6]=s[0][1][1];
// update interior cells
for (k=0;k<F;k++) {
for (j=1;j<=CY;j++) {
for (i=1;i<=CX;i++) {
switch (neighbors(s,k,j,i)) {
case 2: d[k][j][i]=s[k][j][i]; // remain
break;
case 3: d[k][j][i]=1; // birth
break;
default: d[k][j][i]=0; // death
inline uint8_t convert_l(uint8_t l[CXM]) {
return (l[5]|l[4]<<1|l[3]<<2|l[2]<<3|l[1]<<4);
inline uint8_t convert_r(uint8_t l[CXM]) {
return (l[1]|l[2]<<1|l[3]<<2|l[4]<<3|l[5]<<4);
inline uint8_t * board_to_eyes(uint8_t board[F][CYM][CXM]) {
static uint8_t eyes[10]={0,0,0,0,0,0,0,0,0,0};
eyes[0]=convert_l(board[1][5]);
eyes[1]=convert_l(board[1][4]);
eyes[2]=convert_l(board[1][3]);
eyes[3]=convert_l(board[1][2]);
eyes[4]=convert_l(board[1][1]);
eyes[5]=convert_r(board[0][1]);
eyes[6]=convert_r(board[0][2]);
eyes[7]=convert_r(board[0][3]);
eyes[8]=convert_r(board[0][4]);
eyes[9]=convert_r(board[0][5]);
return eyes;
void dump(uint8_t b[][CYM][CXM]) {
uint8_t i,j,k;
Serial.println("==");
for (k=0;k<F;k++) {
Serial.print(b[k][j][i]?'x':'o');
Serial.println("");
void setup(){
delay(2000);
Serial.begin(9600);
Serial.println("life");
clear(board_a); // start with empty board a
clear(board_b); // start with empty board b
//some initial state:
board_a[0][1][2]=1;
board_a[0][2][3]=1;
board_a[0][3][1]=1;
board_a[0][3][2]=1;
board_a[0][3][3]=1;
board_a[1][1][2]=1;
board_a[1][2][3]=1;
board_a[1][3][1]=1;
board_a[1][3][2]=1;
board_a[1][3][3]=1;
Serial.println("inited");
inline void custom_eyes(uint8_t color, uint8_t eyeline[10]){
uint8_t index;
void loop(){
// dump(board_a);
custom_eyes(4,board_to_eyes(board_a));
play(board_a,board_b);
delay(50);
// dump(board_b);
custom_eyes(4,board_to_eyes(board_b));
play(board_b,board_a);
delay(50);
//TODO: add something to react to remote here, e.g. set some cells etc.
irrecv.resume();
} else {
Countdown Timer
This sketch turns Vortex into an eggtimer to be used to keep track of how much time you have left when giving a talk, or before your food is ready. It displays the time left on the eyes, and can be controlled with a IR remote to (re)set the timer. LED colors are adjusted based on the time left, with vortex blinking red when you're out of time.
#include <Wire.h>
#include <FastLED.h>
//IR receiver pin
#define IR_IN (7)
#define I2C_LED_ADDRESS 0b100000
// How many leds are in the strip?
#define NUM_LEDS 12
#define DATA_PIN 13
// how many milliseconds per count (1000=count seconds, 60000 count minutes)
unsigned long MperC=60000;
unsigned long start;
short countdown;
short displayed;
uint8_t state=0;
unsigned long m_elapsed;
short c_elapsed;
unsigned long long current=0xffffffff;
unsigned long long last=0xffffffff;
uint8_t left_digit[10][5]={
{0x04,0x0A,0x0A,0x0A,0x04}, //0
{0x0E,0x04,0x04,0x0C,0x04}, //1
{0x0E,0x08,0x04,0x02,0x0C}, //2
{0x0C,0x02,0x0C,0x02,0x0C}, //3
{0x02,0x02,0x0E,0x0A,0x0A}, //4
{0x0E,0x02,0x0C,0x08,0x0E}, //5
{0x04,0x0A,0x0C,0x08,0x04}, //6
{0x04,0x04,0x02,0x02,0x0C}, //7
{0x04,0x0A,0x04,0x0A,0x04}, //8
{0x04,0x02,0x06,0x0A,0x04} //9
uint8_t right_digit[10][5];
uint8_t swap(uint8_t l) {
switch (l&0x1f){
case 0x0: return 0;
case 0x01: return 0x10;
case 0x02: return 0x08;
case 0x03: return 0x18;
case 0x04: return 0x04;
case 0x05: return 0x14;
case 0x06: return 0x0C;
case 0x07: return 0x1C;
case 0x08: return 0x02;
case 0x09: return 0x12;
case 0x0a: return 0x0A;
case 0x0b: return 0x1A;
case 0x0c: return 0x06;
case 0x0d: return 0x16;
case 0x0e: return 0x0E;
case 0x0f: return 0x1E;
case 0x10: return 0x01;
case 0x11: return 0x11;
case 0x12: return 0x09;
case 0x13: return 0x19;
case 0x14: return 0x05;
case 0x15: return 0x15;
case 0x16: return 0x0D;
case 0x17: return 0x1d;
case 0x18: return 0x03;
case 0x19: return 0x13;
case 0x1a: return 0x0B;
case 0x1b: return 0x1B;
case 0x1c: return 0x07;
case 0x1d: return 0x17;
case 0x1e: return 0x0F;
case 0x1f: return 0x1F;
default: return 0;
void setup(){
char i,j;
delay(2000);
for (i=0;i<10;i++){
for (j=0;j<5;j++) {
right_digit[i][j]=swap(left_digit[i][4-j]);
for (i=0;i<12;i++){
leds[i]=CRGB::Green;
FastLED.show();
start=millis();
displayed=100;
countdown=99;
state=0;
uint8_t index;
// A9 = some sort of multicolor mode
// AA = one color byte, then 10 bytes defining the 2 eyes.
// AB = some sort of multicolor mode
void update_display(short displayed) {
byte h=displayed/10;
byte l=displayed%10;
eyes[0]=left_digit[l][0];
eyes[1]=left_digit[l][1];
eyes[2]=left_digit[l][2];
eyes[3]=left_digit[l][3];
eyes[4]=left_digit[l][4];
eyes[5]=right_digit[h][0];
eyes[6]=right_digit[h][1];
eyes[7]=right_digit[h][2];
eyes[8]=right_digit[h][3];
eyes[9]=right_digit[h][4];
if (displayed<5) {
} else {
custom_eyes(2,eyes);
void update_leds(short displayed) {
char i;
if (displayed>5) {
for (i=0;i<12;i++){
leds[i]=CRGB(0,displayed*2,0);
} else if (displayed>0) {
for (i=0;i<12;i++){
leds[i]=0xff9900;
} else if (state==1) {
for (i=0;i<6;i++) {
leds[i]=CRGB::Red;
leds[i+6]=CRGB::Black;
state=0;
} else if (state==0) {
for (i=0;i<6;i++) {
leds[i+6]=CRGB::Red;
leds[i]=CRGB::Black;
state=1;
FastLED.show();
void loop(){
unsigned long m_elapsed=millis()-start;
// FIXME handle overflow of millis.
short c_elapsed=(m_elapsed/MperC);
if (displayed>0) {
if (countdown-c_elapsed!=displayed) {
displayed=countdown-c_elapsed;
displayed=displayed<0?0:displayed;
update_display(displayed);
update_leds(displayed);
//TODO check IR commands
current=results.value;
if (current!=last) {
last=current; // store current key to be able to recognize repeats
current=current&0xfffff7ff; // filter out repeat bit. This is for RC5.
if (current==0xa) { // 'clear' on my particular remote
countdown=0;
} else if (current==0xf) { // 'memo'
start=millis(); // reference time is now
displayed=99; // restarts timer with current countdown setting
} else if (current==0x0) { // 'digit 0', not all remotes might be this regular
digit(0);
} else if (current==0x1) {
digit(1);
} else if (current==0x2) {
digit(2);
} else if (current==0x3) {
digit(3);
} else if (current==0x4) {
digit(4);
} else if (current==0x5) {
digit(5);
} else if (current==0x6) {
digit(6);
} else if (current==0x7) {
digit(7);
} else if (current==0x8) {
digit(8);
} else if (current==0x9) {
digit(9);
} else if (current==0x0) { // TODO add pause, up/down by 1
delay(500);
void digit(byte d) {
displayed=0; // stops timer updates to display
countdown=(countdown%10)*10+d;
update_display(countdown);
i2c
There might be more stuff connected to the i2c already, I plan to do some tests to find out. Would be nice if e.g. the flash of the mp3 player or some other expansion was already there.
Regardless of what's there already, Vortex seems to be designed to be extended over i2c, and could be a nice platform to do some experiments/demo's with.
Here's a simple scanning sketch, looks like only 0x40 has something connected, and that would be the eye-display.
#include <Wire.h>
void setup()
Wire.begin();
Serial.begin(9600);
while (!Serial); // Leonardo: wait for serial monitor
Serial.println("\nI2C Scanner");
void loop()
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 0; address < 128; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.print(" (");
Serial.print(address,DEC);
Serial.println("d) !");
nDevices++;
else if (error==4)
Serial.print("Unknown error at address 0x");
if (address<16)
Serial.print("0");
Serial.print(" (");
if (nDevices == 0)
Serial.println("No I2C devices found\n");
else
Serial.println("done\n");
delay(5000); // wait 5 seconds for next scan
Bluetooth
It seems the Bluetooth functionality is the same as for the "Bluno" and thus the information at https://www.dfrobot.com/wiki/index.php/Bluno_SKU:DFR0267#Wireless_Programming_via_BLE applies.
The AT commands seem to work, up to a point, but looks like it is a somewhat variant version of the firmware as AT+VERSION command doesn't work. Updating program seem not available for Linux.
Booting the Vortex with the 'boot' button (near UL7, Vortex bottom-right-back RGB led.), two leds blink, and linux detects the Vortex over USB as:
[230656.359259] usb 1-1.1: new full-speed USB device number 103 using xhci_hcd [230656.488502] usb 1-1.1: New USB device found, idVendor=2341, idProduct=0043 [230656.488508] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [230656.488511] usb 1-1.1: Product: DFRobot Boot CDC [230656.488513] usb 1-1.1: Manufacturer: DFRobot BLUno Boot [230656.490491] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
Similarly the little BLE dongle comes up as:
[232626.931574] usb 1-1.3: new full-speed USB device number 108 using xhci_hcd [232627.254357] usb 1-1.3: New USB device found, idVendor=2341, idProduct=0043 [232627.254362] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [232627.265758] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
If Vortex pairs with the dongle, it effectiely gains an additional, wireless, serial link to a different port on the host. It's connected to the same Serial port on the internal Arduino. Make sure to adjust speed setting to what is used in the currently running sketch, the default 115200 won't work if Serial.begin(9600) is already called..
Using AT commands it should be possible to set up the link connect to other Vortex robots too.
Need to do some experiments to see if it is possible to connect to a generic Bluetooth 4.x dongle too.
Expansion
There are 2 sets of 4 positions for screws/bolts at the top of the vortex, around the battery compartment, obviously to be used to put an expansion unit on top of Vortex, which could be linked to the i2c bus.
Dimensions
The bigger set of holes are 65 mm apart from left to right and 55 from front to back (center to center). These seem to be meant for 3 mm machine screws
The smaller set of holes are 2.5" apart from left to right and 2.75" from front to back (center to center). These seem to be meant for small screws biting into the plastic.
The 4 pin expansion port
Q: Does Vortex support sensor module expansion? A: Vortex has a “Maker mode” where you can connect sensors via its IIC/TWI interface.
It would seem the only logical place for this is the 4 pin connector in the back. Looking at the connector from the back of Vortex:
____ |1234| -__-
These pins seem to be connected to the rainbow cable coming up from the main PCB as follows:
| Pin | Function | Color |
| 1 | SDA? | ~15kOhm to Blue |
| 2 | SCL? | Blue |
| 3 | Gnd? | Black |
| 4 | Vcc? | Red |
It would make sense for Red to be 5V, Black to be Gnd, and the other two SCL and SDA of the i2c bus. This needs some further testing, preferably with a known good i2c device connected to the expansion port. The ~15kOhm between what I suspect to be SCL and SDA would then be two ~7.5kOhm to some common 5 V point that is buffered from the 'Red' cable.
