Luteijn/IRRemotes
Project "IRRemotes":
Project Luteijn/IRRemotes | |
Contact | Luteijn |
Last Update | 2018-02-04 |
IRRemotes
Controlling things with an IR Remote is fun. Here's what some of my remotes send out, for easy (re)use in projects with an IR Receiver. Sniffed the codes with a Vortex robot, made up the names in the tables myself.
RC6 'windows' remote
This sends 36-bit RC6 codes. They all seem to be of the form 0xC8034x4hl. The leading C doesn't show with my current decoder of choice, or isn't really there. The x is either 8 or 0, flipping for each key pressed, so you can distinguish between a key being held or pushed twice in a row. The h and l indicate the variable bits in the code sent, the tables below give a name to each of these.
For this first table, the order is a left to right, top to bottom scan of the remote, treating the volume and channel + - as one, rocker, button.
Code | Label | Code | Label | Code | Label | Code | Label | Code | Label | Code | Label | |||||
0C | power | 30 | pause | 37 | record | 31 | stop | 29 | reverse | 2C | play | |||||
28 | forwards | 21 | previous | 20 | next | 83 | back | CB | info | 58 | up | |||||
5A | left | 5C | ok | 5B | right | 59 | down | 10 | vol+ | 11 | vol- | |||||
5D | logo | 1E | ch+ | 1F | ch- | 0D | mute | 9B | tvrecord | 3E | tvguide | |||||
2E | tvplay | 54 | disc | 01 | 1 | 02 | 2 | 03 | 3 | 04 | 4 | |||||
05 | 5 | 06 | 6 | 07 | 7 | 08 | 8 | 09 | 9 | 33 | * | |||||
00 | 0 | 32 | # | 3A | clear | 2F | teletext | 34 | enter | 6D | red | |||||
6E | green | 6F | yellow | 70 | blue |
The next table is sorted by in the code order:
00 | 0 | 01 | 1 | 02 | 2 | 03 | 3 | 04 | 4 | 05 | 5 | |||||
06 | 6 | 07 | 7 | 08 | 8 | 09 | 9 | 0C | power | 0D | mute | |||||
10 | vol+ | 11 | vol- | 1E | ch+ | 1F | ch- | 20 | next | 21 | previous | |||||
28 | forwards | 29 | reverse | 2C | play | 2E | tvplay | 2F | teletext | 30 | pause | |||||
31 | stop | 32 | # | 33 | * | 34 | enter | 37 | record | 3A | clear | |||||
3E | tvguide | 54 | disc | 58 | up | 59 | down | 5A | left | 5B | right | |||||
5C | ok | 5D | logo | 6D | red | 6E | green | 6F | yellow | 70 | blue | |||||
83 | back | 9B | tvrecord | CB | info |
RTeL-Cheapo remote
This El-Cheapo remote came with one of my RTL-dongles. Decodes as an NEC-code, sending a '32-bit' code when a key is pressed, followed by a 0-bit code as long as the key is held. Only the lowest 16 bits seem to change. The keypad is a 3x67 matrix
FFB24D | power | FF2AD5 | source | FF6897 | mute | ||
FF32CD | record | FFA05F | ch+ | FF30CF | time shift | ||
FF50AF | vol- | FF02FD | full screen | FF7887 | vol+ | ||
FF48B7 | 0 | FF40BF | ch- | FF38C7 | recall | ||
FF906F | 1 | FFB847 | 2 | FFF807 | 3 | ||
FFB04F | 4 | FF9867 | 5 | FFD827 | 6 | ||
FF8877 | 7 | FFA857 | 8 | FFE817 | 9 |
Shinco RC-1606
This remote came with our Chinese DVD player many of the key labels are in Chinese. Decodes as an NEC-code, and like the RTeL-Cheapo remote it will send a '32-bit' code when a key is first pressed, and then a 0-bit code as long as it is held. Only the lowest 16 bits seem to change. The basic layout is 4 buttons per row, but the central bit is 3 rows of 3 slightly larger buttons.
99728D | screen display | 9938C7 | power | |||||||
996A95 | subtitles | 99CA35 | language | 9918E7 | channel | 992AD5 | point of | |||
99807F | repeat | 99D02F | pause | 9900FF | play mode | 9942BD | progressive/interlaced | |||
99B24D | set | 99E01F | title | 9930CF | menu | 9950AF | return | |||
997887 | previous | 993AC5 | up | 99DA25 | next | |||||
997A85 | left | 9928D7 | play | 99FA05 | right | |||||
99708F | reverse | 99BA45 | down | 9968A7 | forward | |||||
99F00F | stop | 99C837 | pause | 99EA15 | step | 99A05F | time search | |||
99906F | 1 | 99B847 | 2 | 99F807 | 3 | 99F20D | +5 | |||
99B04F | 4 | 999867 | 5 | 9948B7 | 0 | 99609F | mute | |||
9902FD | standard | 9940BF | bookmark | 99E21D | V- | 9912ED | V+ |
Xtreamer
This remote came with my 'Xtreamer'; many of the keys have more than one label, as they are used differently depending on context. Decodes as an NEC-code, and like the RTeL-Cheapo remote it will send a '32-bit' code when a key is first pressed, and then a 0-bit code as long as it is held. Only the lowest 16 bits seem to change. The basic layout is 3 buttons per row.
FF20DF | power | FFDA25 | home | ||||
FFA25D | 1 / add / red | FFE817 | 1 / eject / green | FF48B7 | 3 / delete / yellow | ||
FFF20D | 4 / zoom | FFC03F | 5 / goto / blue | FF906F | 6 / menu | ||
FF38C7 | 7 / setup | FF4CB3 | 8 / func | FF9867 | 9 / tvout | ||
FF5AA5 | info | FF8C73 | 0 / preview | FF50AF | return | ||
FF728D | up | ||||||
FF30CF | left | FF609F | enter | FFA05F | right | ||
FFB24D | down | ||||||
FF1AE5 | previous / pgup | FF0AF5 | next / pgdn | ||||
FF32CD | pause/play | FF7887 | stop | ||||
FF3AC5 | reverse | FFD22D | forwards | FF18E7 | vol+ | ||
FF708F | audio | FF00FF | A-B | FF827D | vol- | ||
FFCC33 | shuffle | FF08F7 | repeat | FF58A7 | mute | ||
FFF00F | subtitle | FF807F | sync subtitle << | FF12ED | sync subtitle >> |
Amoi RC305T
This remote came with my 37 inch LCD tv; some of the keys have more than one label, as they are used differently depending on context. Decodes as an NEC-code, and like the RTeL-Cheapo remote it will send a '32-bit' code when a key is first pressed, and then a 0-bit code as long as it is held. Only the lowest 16 bits seem to change. The basic layout is 4 buttons per row. Some of the number keys are not responding anymore
40BD02FD | power | |||||||||
40BD708F | source | 40BD728D | sub source | 40BDF20D | last source | 40BD827D | mute | |||
40BDC23D | freeze | 40BD8A75 | aspect | 40BD629D | sleep | 40BD50AF | display | |||
40BD6A95 | video off | 40BDAA55 | swap | 40BD926D | pip/pbp | 40BD2AD5 | pop | |||
40BD42BD | picture | 40BDE21D | sound | 40BDEA15 | headphone - | 40BD1AE5 | headphone + | |||
40BD???? | 1 / symbol | 40BD40BF | 2 / abc | 40BDC03F | 3 / def | 40BDD02F | dual | |||
40BD???? | 4 / ghi | 40BDA05F | 5 / jkl | 40BD609F | 6 / mno | 40BDB04F | swap | |||
40BDE01F | 7 / pqrs | 40BD10EF | 8 / tuv | 40BD???? | 9 / wxyz | 40BD00FF | 0 / space | |||
40BDE817 | volume + | 40BD30CF | list | 40BD22DD | page >> | 40BD6897 | ch + | |||
40BDA857 | volume - | 40BD28D7 | menu | 40BDA25D | page << | 40BD18E7 | ch - | |||
40BDC837 | up / teletext next subpage | |||||||||
40BD08F7 | left | 40BD9867 | ok / teletext info | 40BD48B7 | right | |||||
40BD8877 | down / teletext previous subpage | |||||||||
40BD12ED | play / pause / teletext x | 40BDB24D | stop / teletext zoom upper | 40BD52AD | digest / teletext zoom lower | 40BDF00F | exit | |||
40BD9A65 | zoom / teletext no zoom | 40BDD22D | rotate / teletext hold | 40BD32CD | function / teletext reveal | 40BD0AF5 | txt / mix / teletext | |||
40BD4AB5 | red | 40BDCA35 | green | 40BD5AA5 | yellow | 40BDDA25 | blue |
