Luteijn/IRRemotes
Project "IRRemotes":
Project Luteijn/IRRemotes
Bestand:I.R. Baboon 301-1-.png
Contact Luteijn
Last Update 2018-02-04
IRRemotes
Controlling things with an IR Remote is fun. Here's what some of my remotes send out, for easy (re)use in projects with an IR Receiver. Sniffed the codes with a Vortex robot, made up the names in the tables myself.
RC6 'windows' remote
This sends 36-bit RC6 codes. They all seem to be of the form 0xC8034x4hl. The leading C doesn't show with my current decoder of choice, or isn't really there. The x is either 8 or 0, flipping for each key pressed, so you can distinguish between a key being held or pushed twice in a row. The h and l indicate the variable bits in the code sent, the tables below give a name to each of these.
For this first table, the order is a left to right, top to bottom scan of the remote, treating the volume and channel + - as one, rocker, button.
RC6 'windows'
Code Label Code Label Code Label Code Label Code Label Code Label
0C power 30 pause 37 record 31 stop 29 reverse 2C play
28 forwards 21 previous 20 next 83 back CB info 58 up
5A left 5C ok 5B right 59 down 10 vol+ 11 vol-
5D logo 1E ch+ 1F ch- 0D mute 9B tvrecord 3E tvguide
2E tvplay 54 disc 01 1 02 2 03 3 04 4
05 5 06 6 07 7 08 8 09 9 33 *
00 0 32 # 3A clear 2F teletext 34 enter 6D red
6E green 6F yellow 70 blue
The next table is sorted by in the code order:
RC6 'windows'
00 0 01 1 02 2 03 3 04 4 05 5
06 6 07 7 08 8 09 9 0C power 0D mute
10 vol+ 11 vol- 1E ch+ 1F ch- 20 next 21 previous
28 forwards 29 reverse 2C play 2E tvplay 2F teletext 30 pause
31 stop 32 # 33 * 34 enter 37 record 3A clear
3E tvguide 54 disc 58 up 59 down 5A left 5B right
5C ok 5D logo 6D red 6E green 6F yellow 70 blue
83 back 9B tvrecord CB info
RTeL-Cheapo remote
This El-Cheapo remote came with one of my RTL-dongles. Decodes as an NEC-code, sending a '32-bit' code when a key is pressed, followed by a 0-bit code as long as the key is held. Only the lowest 16 bits seem to change. The keypad is a 3x67 matrix
RTeL-Cheapo
FFB24D power FF2AD5 source FF6897 mute
FF32CD record FFA05F ch+ FF30CF time shift
FF50AF vol- FF02FD full screen FF7887 vol+
FF48B7 0 FF40BF ch- FF38C7 recall
FF906F 1 FFB847 2 FFF807 3
FFB04F 4 FF9867 5 FFD827 6
FF8877 7 FFA857 8 FFE817 9
Shinco RC-1606
This remote came with our Chinese DVD player many of the key labels are in Chinese. Decodes as an NEC-code, and like the RTeL-Cheapo remote it will send a '32-bit' code when a key is first pressed, and then a 0-bit code as long as it is held. Only the lowest 16 bits seem to change. The basic layout is 4 buttons per row, but the central bit is 3 rows of 3 slightly larger buttons.
Shinco RC-160S
99728D screen display 9938C7 power
996A95 subtitles 99CA35 language 9918E7 channel 992AD5 point of
99807F repeat 99D02F pause 9900FF play mode 9942BD progressive/interlaced
99B24D set 99E01F title 9930CF menu 9950AF return
997887 previous 993AC5 up 99DA25 next
997A85 left 9928D7 play 99FA05 right
99708F reverse 99BA45 down 9968A7 forward
99F00F stop 99C837 pause 99EA15 step 99A05F time search
99906F 1 99B847 2 99F807 3 99F20D +5
99B04F 4 999867 5 9948B7 0 99609F mute
9902FD standard 9940BF bookmark 99E21D V- 9912ED V+
Xtreamer
This remote came with my 'Xtreamer'; many of the keys have more than one label, as they are used differently depending on context. Decodes as an NEC-code, and like the RTeL-Cheapo remote it will send a '32-bit' code when a key is first pressed, and then a 0-bit code as long as it is held. Only the lowest 16 bits seem to change. The basic layout is 3 buttons per row.
Xtreamer
FF20DF power FFDA25 home
FFA25D 1 / add / red FFE817 1 / eject / green FF48B7 3 / delete / yellow
FFF20D 4 / zoom FFC03F 5 / goto / blue FF906F 6 / menu
FF38C7 7 / setup FF4CB3 8 / func FF9867 9 / tvout
FF5AA5 info FF8C73 0 / preview FF50AF return
FF728D up
FF30CF left FF609F enter FFA05F right
FFB24D down
FF1AE5 previous / pgup FF0AF5 next / pgdn
FF32CD pause/play FF7887 stop
FF3AC5 reverse FFD22D forwards FF18E7 vol+
FF708F audio FF00FF A-B FF827D vol-
FFCC33 shuffle FF08F7 repeat FF58A7 mute
FFF00F subtitle FF807F sync subtitle << FF12ED sync subtitle >>
Amoi RC305T
This remote came with my 37 inch LCD tv; some of the keys have more than one label, as they are used differently depending on context. Decodes as an NEC-code, and like the RTeL-Cheapo remote it will send a '32-bit' code when a key is first pressed, and then a 0-bit code as long as it is held. Only the lowest 16 bits seem to change. The basic layout is 4 buttons per row.
Amoi RC305T
40BD02FD power
