Geigercounter
Revision as of 22:12, 23 November 2017 by Bertrik Sikken (talk | contribs) (explain software a bit)
Project Geiger counter
A geiger counter for the space
Contact gori, thomas
Last Update 2017-11-23
See the geiger_esp sub-directory in this github repo
The way the ESP8266 version of the software works, is by means of a single pulse counter. This counter is incremented for every tick coming from the Geiger tube.
Every second we keep track how much the counter has incremented compared to the previous second. This value is stored in a circular buffer of 60 entries, one for each second inside of a minute.
The 'cpm' value (counts per minute) is then simply the sum of all entries in the circular buffer! So we can calculate the cpm at any time, without rounding error, it's always the number of measured ticks in the previous 60 seconds.
The software uses the following libraries:
  • WiFiClient for general WiFi
  • WifiManager to make it easy to setup the WiFi (presents a captive portal to select a network and enter the passphrase)
  • PubSubClient to publish measurements to MQTT
Measurements are published to topic 'revspace/sensors/geiger' on mosquitto.space.revspace.nl (also available on revspace.nl)
Pitch in for a geiger counter:
Naam/Nick Aantal euro's Betalingsmethode
gori 5
Walter 5 revbank
Jos 5 revbank
thomas 5 revbank (Betaald)
Peetz0r 5 revbank
merethan 5 Western Union
pepman 5 revbank
bertrik Wemos D1 mini natura
DONE! thank you all.
