CrawlSpaceSensor
Revision as of 08:07, 4 May 2017 by Bertrik Sikken (talk | contribs) (Update DHT11 pins and power consumption calculation)
Project CrawlSpaceSensor
Sensor inside crawl space
Status Initializing
Last Update 2017-05-04
  • water level (in case it is flooded), using a VL53L0X lidar sensor
  • humidity and temperature using a DHT11 or DHT22
TODO:
  • think about the measurement mechanics: direct measurement of level, or floaty thing (ball) in a tube
Theory
Reflection
The range measurement of the VL53L0X module is based on time-of-flight of the laser signal reflecting off a surface.
Wikipedia shows the formula for the reflection off an interface between two materials with different refractive index at normal incidence, examples:
  • for air-glass, we have n1=1.00 and n2=1.50, the reflection coefficient is 4%.
  • for air-water, we have n1=1.00 and n2=1.33, the reflection coefficient is 2%.
A reflection coefficient of 2% is quite low, and indeed some experimentation showed difficulties determining range towards the fluid level in a glass of water. Perhaps a practical way is to measure distance to some floating object instead, like a piece of white polystyrene foam, or a ping-pong ball.
Calibration
We're considering only a ranging offset error in the measurement system.
Assume:
  • L is the water level (mm)
  • R is the distance measured by the lidar between the module and the water
The water level L can be calculated from the range R as follows:
 level L (mm) = Constant C (mm) - range R (mm)
So, once we know the actual water level L (as measured using some external means) and range R (as measured by the lidar module), we can calculate the constant C as:
 C = L + R
Design
The plan is to use an ESP8266 to read the sensors, connect to the house WiFi and upload the measurement data once an hour. When not measuring, the ESP8266 is put in deep-sleep mode. Time-of-day is retrieved using (S)NTP.
  • ESP8266 in a Wemos D1 mini board, because they're so easy to use
  • LiFePO4 battery, because they have about the right voltage for direct drive and are safe to use
  • VL53L0X LIDAR module to accurately measure the water level
  • DHT11, DHT22 or AM2302 to measure humidity and temperature
Pin connections
ESP8266 pin Connect to Remark
D0 ESP8266 RESET Loopback wire to allow the ESP to wake itself from deep sleep
D1 VL53L0X SCL I2C clock
D2 VL53L0X SDA I2C data
D3 VL53L0X SHDN Shutdown pin
D5 DHT11 GND GND from GPIO
D6 DHT11 DATA DHT11 DATA pin
D7 DHT11 VIN Power supply from GPIO
3V3 VL53L0X VIN Power supply
GND VL53L0X GND Ground
VL53L0X LIDAR
Taking a measurement after reset requires a couple of initialisation/calibration steps, I need to figure out which ones are actually relevant for my use case.
  • high accuracy
  • high speed
  • long range.
The API user manual indicates the following settings for high accuracy mode:
  • a "signal rate" of 0.25 (I guess this is a measure for the amplitude of the laser return signal)
  • a "sigma" of 18 mm
  • a measurement timing budget of 200 ms
I think the accuracy can be further improved, e.g. by increasing the measurement time and reducing the sigma limit. According to the remark mentioned earlier, I expect that doubling the accuracy requires four times the measurement time. So for example, I think it should be possible to spend 3200 ms instead of 200 ms on the measurement, which theoretically should give 4 times the accuracy.
Using a cover glass on top of the sensor makes things more complicated, so I plan to not use a cover glass.
Source code
The source code for the measurement application is available on github.
Measurement cycle timing
  • wake up from deep sleep (0.3s)
  • connect and authenticate to the WiFi (4.8s)
  • perform an SNTP request to get the current date/time (0.1s)
  • perform a distance measurement using the LIDAR (0.2s)
  • perform temperature/humidity measurement (0.1s)
  • publish measurements to MQTT (0.1s)
  • calculate sleep time until next wakeup and enter deep-sleep (0.0s)
Total about 5.6 seconds per measurement cycle.
Initially, when no WiFi network is known, the sensor starts its own access point presenting a captive portal allowing a WiFi network to be selected.
Data format
The plan is to encode the measurement data in JSON and post it as text on a MQTT topic.
Exampled of proposed data format:
    "id": "12AABB",
    "time": 123456789,
    "humidity": 87,
    "temperature": 21.4,
    "range": 78
Where id is the ESP8266 unique id (in hex), time is in seconds since 1970/1/1 (UTC), humidity in percent, temperature in degrees Celcius and range in millimeters.
The "range" value represents the distance between the sensor and the fluid. A higher range means a lower fluid level.
Libraries
The plan is to use the following libraries:
  • WifiManager to handle WiFi authentication and presenting a captive portal if it cannot authenticate
  • pololu VL53L0X library
Battery Life
Sleep current is estimated to be about 0.15 mA total (about 80 uA for the ESP8266 in deep-sleep, about 50 uA for the DHT11/22, about 5 uA for the VL53L0X in HW standby mode).
When awake, current consumption is estimated to take 70 mA on average for 5.6 seconds. This means each measurement takes about 0.11 mAh.
So, over one measurement cycle of one hour, total charge consumed sums up to a total of about 0.26 mAh. With a 700 mAh battery this would allow about 2500 measurements, making the battery last about 100 days.
Interesting links
