CrawlSpaceSensor
Project CrawlSpaceSensor | |
File:Whyunoimage.png | |
Sensor inside crawl space | |
Status | Initializing |
Contact | bertrik |
Last Update | 2017-04-25 |
- water level (in case it is flooded), using a VL53L0X lidar sensor
- humidity and temperature using a DHT11 or DHT22
Theory
The distance measurement of the VL53L0X module is based on time-of-flight of the laser signal reflecting off a surface.
Wikipedia shows the formula for the reflection off an interface between two materials with different refractive index.
For air-glass, we have n1=1.00 and n2=1.50, the reflection coefficient is 4%.
For air-water, we have n1=1.00 and n2=1.33, the reflection coefficient is 2%.
Design
The plan is to use an ESP8266 to read the sensors, connect to the house WiFi and upload the measurement data once an hour. When not measuring, the ESP8266 is put in deep-sleep mode. Time-of-day is retrieved using (S)NTP.
- ESP8266 in a Wemos D1 mini board, because they're so easy to use
- LiFePO4 battery, because they have about the right voltage for direct drive and are safe to use
- VL53L0X LIDAR module to accurately measure the water level
- DHT11 or DHT22 to measure humidity and temperature
VL53L0X LIDAR
Taking a measurement after reset requires a couple of initialisation/calibration steps, I need to figure out which ones are actually relevant for my use case.
- high accuracy
- high speed
- long range.
The API user manual indicates the following settings for high accuracy mode:
- a "signal rate" of 0.25 (I guess this is a measure for the amplitude of the laser return signal)
- a "sigma" of 18 mm
- a measurement timing budget of 200 ms
I think the accuracy can be further improved, e.g. by increasing the measurement time and reducing the sigma limit. According to the remark mentioned earlier, I expect that doubling the accuracy requires four times the measurement time. So for example, I think it should be possible to spend 3200 ms instead of 200 ms on the measurement, which theoretically should give 4 times the accuracy.
Using a cover glass on top of the sensor makes things more complicated, so I plan to not use a cover glass.
Measurement cycle
- wake up from deep sleep (1.0s)
- connect and authenticate to the WiFi (3.0s)
- perform an SNTP request to get the current date/time (1.0s)
- perform a distance measurement using the LIDAR (3.0s)
- perform temperature/humidity measurement (1.0s)
- publish measurements to MQTT (1.0s)
- calculate sleep time until next wakeup and enter deep-sleep (0.0s)
Total about 10 seconds per measurement cycle.
Initially, when no WiFi network is known, the sensor starts its own access point presenting a captive portal allowing a WiFi network to be selected.
Data format
The plan is to encode the measurement data in JSON and post it as text on a MQTT topic.
Exampled of proposed data format:
{ "time": 123456789, "humidity": 87.0, "temperature": 21.4, "range": 78.5 }
Where time is in seconds since 1970/1/1 (UTC), humidity in percent, temperature in degrees Celcius and range in millimeters.
The "range" value represents the distance between the sensor and the fluid. A higher range means a lower fluid level.
Battery Life
Sleep current is estimated to be about 0.10 mA total (about 80 uA for the ESP8266 in deep-sleep, about 5 uA for the VL53L0X in HW standby mode).
When awake, current consumption is estimated to take 100 mA on average for 10 seconds. This means each measurement takes about 0.28 mAh.
So, over one measurement cycle of one hour, we consume about 0.10 mAh in sleep-current and about 0.28 mAh in run-current, for a total of about 0.38 mAh. With a 700 mAh battery this would allow about 1800 measurements, making the battery last about 76 days.
Interesting links
- The STSW-IMG005 library from ST
- Video showing this module being used to measure fluid level
- Liquid level sensor using a laser time of flight sensor by David Pilling
