SE30
Revision as of 14:03, 23 October 2016 by Bas (talk | contribs)
Project SE30
Teaching an old Mac new trics
Contact Sebastius
Last Update 2016-10-23
Regifted to AwesomeRetro
Got an old Macintosh SE30 donated. It was broken (Simasi-Mac), but the harddrive was spinning. Worth repairing!
I have some experience with the SE30, this is actually my second unit to repair:
That unit i still own, but the harddrive was dead and unfixable. If all else fails i'll use the logicboard from my working unit to fix this one. But first i'll try and repair it!
Getting the hardware working
Leaky caps
The SE30 is known for leaky capacitors (also the main backup-battery tends to leak or explode...). Removed all electrolytic caps (except the big blue ones). Cleaned the old solder off, washed the board with Isopropyl Alcohol and a toothbrush to stop the corrosion. Repaired a few via's that were corroded (didnt measure, just resoldered them with fresh solder and flux). Then placed new caps: used 100uF instead of 47uF because that's what i had lying around. The 1uF cap is replaced with a non-SMT 2.2uF cap, for the same reasons.
Look closely and you can see the ooze and the corrosion it caused...
Works!
Well... That was fast!
