Verint Nextiva
Versie door Peetz0r (overleg | bijdragen) op 3 jun 2016 om 19:02 (project box filled in)
Project Verint Nextiva
8-channel video encoder
Status In Progress“In Progress” staat niet in de lijst met mogelijke waarden voor de eigenschap “Project Status” (Proposed, Initializing, In progress, Completed, Stalled, Abandoned).
Contact User:Peetz0r
Last Update 2016-06-03
We have old analog camera's around the space that have been used in the past but are unconnected now. They do have power and they work!
Sk1llz has had a donation from Griffid with some old video encoders. One of them is a 8 channel Verint Nextiva S1708e
Peetz0r, participant at both spaces, re-donated the decoder and tried to make it work. Spoiler alert: it works!
Network config
The thing does not have a web interface. It does have telnet and it streams video over RTP.
DHCP is enabled right now, and it's IP is 10.42.43.92.
Video config
Telnet to the thing, and go (6) Advanced => (1) Video => (X) Input X => (1) Encoder 1 and make sure it looks like this:
*       Verint Video Solutions S1708e - 10.42.43.92       *
Video \ Input 8  \ Encoder 1
Parameters:
 1) Target Bit Rate                        : 800 kbits/second
 2) Target Frame Rate                      : 25 frames/second
 3) Minimum Quantizer                      : 2
 4) Maximum Quantizer                      : 24
 5) Initial Streaming                      : Enabled
 6) Current Streaming State                : Enabled
 7) Transport Protocol                     : RTP/UDP
 8) Input Filter Mode                      : Low
 9) Noise Reduction Filter Mode            : Low
10) Resolution                             : 4CIF (704x576)
11) Remote IP Address                      : 10.42.43.45
12) UDP Data Port                          : 2543
13) Rate Control Mode                      : CBR (Constant Bitrate)
14) Multiplying factor for Nextiva RC (X100: 150
15) Target VSIP GUID                       : 00000000-0000-0000-0000-000000000000
16) Intra Interval                         : 120
17) Energy Vector (EV) transmission rate   : 0
18) Compression Mode                       : MPEG4 Compliant Simple Profile
19) Frame Format                           : DeInterlaced Frame
20) Sabotage Detection Filter Mode         : None
Commands:
p) Previous Menu
Command:
Change (11) Remote IP Address to your device (let's say, a laptop running linux) and (12) UDP port to anything.
The led for the chosen input should now be flashing quickly. Preferably green, because that means that the connected input works. But red is okay for testing your config.
Now move over to your linux machine. At first I tried vlc and I even fiddled around with SDP files. Then I stumbled upon https://wiki.london.hackspace.org.uk/view/Project:Verint which barely helped. The next day, I found this mailing list thread and especially this mail.
Then I created this command line:
gst-launch-0.10 -e -v udpsrc port=2543 ! application/x-rtp,media=video,payload=121,clock-rate=90000,encoding-name=MP4V-ES,profile-level-id=1 ! rtpmp4vdepay ! decodebin ! autovideosink
It works!!!
POIDH
The Verint Nextiva S1708e video encoder connected to a freestuff dvd player (as test video source) successfully streaming to my laptop.
RTFM
Bestand:Nextiva S1708e Data Sheet.pdf
Bestand:S1704e m.pdf (Nextiva Multiport S17XXe Series User Guide)
