EspWifiTracker
| Project EspWifiTracker | |
| 350px | |
| Location-tracker based on WiFi station ids | |
| Status | Initializing |
| Last Update | 2016-03-06 |
- track your own bicycle
- know where your cat goes
- monitor movement of wild animals for research purposes, like bats or stone martens.
- the tracker is in deep-sleep most of the time, keeping only a low-power real-time-clock running.
- every once in a while (say once a day) it wakes up, takes a reading of all WiFi stations in range and their signal strength. It stores these in internal memory.
- if the tracker wakes up to find an open WiFi station (or one that it knows the WiFi password of), it tries to upload all previous readings to a server.
- the server resolves the uploaded data into geographical locations using a service like Google or the Mozilla Location Service.
Tracker prototype
I'm working on a prototype of this.
I'm basing this off an inexpensive NodeMCU clone. The NodeMCU is basically an ESP8266-module on a break-out board with an USB-serial converter and a proper 3.3V power supply. The ESP8266 is a WiFi-capable microcontroller, capable of running at 80 MHz and having 1 MB of flash onboard.
To wake up periodically, I'm using a ZS-042 clock module, containing a Maxim DS3231 RTC chip. This module is attached to the NodeMCU through the I2C-bus on pins D1 (SCL) and D2 (SDA).
The NodeMCU can be conveniently programmed from the "Arduino" development environment using the Arduino core for ESP8266 WiFi chip
Other libraries used:
- Makuna RTC
Server backend
- Google maps geolocation API
- Mozilla Location Service
- OpenWLANmap.org (what is this project actually called?)
- see also this page on Wikipedia.
- one to upload data from the tracker to the server
- one to provide configuration data from the server to the tracker
- a new periodic wake-up schedule
- list of known WiFi stations + passwords
- WiFi station whitelist, list of stations which are known to be really open to the internet
- WiFi station blacklist, list of stations which are open (unencrypted), but not really open to the internet
Challenges
Some things to solve yet:
- first of all make a working prototype
- using "WiFi hotspots": bypass so-called captive portals. Many open web services spoof DNS after connecting to the access point and re-direct you to a webpage where you either need to log in or click some 'I agree' button. It's easy for a human to understand this, possibly not so easy for an embedded device.
- make it lower power: so we can use a smaller battery or get longer tracking time
- make it smaller and lighter: so it can be attached to smaller items (e.g. a migrating bat)
