ZX81PLUS35 ZX81 clone
Introduction to the ZX81+34
The ZX81+34 is a much improved ZX81 that people can build themselves. At the moment the PCB of the first prototype has been designed, and is ready to be tested.
The ZX81+34 should be fully compatible with the original ZX81, but with the following improvements over the original ZX81 :
- Supports ZX81 BASIC in either a EEPROM or in an OTP (one time programmable ROM)
- Can drive a simple LCD display, and some external I/O for "stand alone" applications like driving tiny robots. Debug LED/Backlight LED support.
- Design files freely available (but do note that firmware is still © Amstrad!)
3D Preview of early ZX81+34
Before I even designed the PCB I made a mockup with Altium. Here are two (3D rendered) previews of the ZX81+34 board, to the left is an older small preview of the complete system, including how I envisaged the whole system with keyboard would look like, at the center a picture of the more recent 3D rendering of ZX81+34 PCB, and to the right, as a size reference the original ZX81. Note both PCB's are about equally as tall (10 cm), but the ZX81+34 is much smaller, as it square, while the ZX81 is much wider than it is tall. The right picture also shows the four chips of the original ZX81, and what replaces them on the ZX81+34
Schematic 81+34
The latest schematic (.PDF) can be found here: Bestand:ZX81+34 schema.pdf
There is also a color coded schematic (.PDF), it can be found here: Bestand:ZX81+34 kleur rev 1.0.pdf. Note that SMT components are depicted purple, and PTH ones green.
Layout ZX81+34
Keyboard (ZX81+34)
Here is the schematic and board layout of the keyboard: Bestand:KB matrix schematic.pdf
The final ZX81+34
Finally mid January 2015 the PCB of the ZX81+34 was finished, a mounting hole was added (needed to mount in an enclosure, and to connect shielding, if you want to add that). The picture below is a 3D rendered preview, some of the texts on the preview are there to comment some of the functions, and will not be present on the silkscreen of the final PCB.
