ZX81PLUS35 ZX81 clone
Introduction to the ZX14/15
The ZX15 is a much improved ZX81 that people can build themselves. At the moment the PCB of the first prototype has been designed, and is ready to be tested.
The ZX14 should be fully compatible with the original ZX81, but with the following improvements over the original ZX81 :
- Supports ZX81 BASIC in either a EEPROM or in an OTP (one time programmable ROM)
- Can drive a simple LCD display, and some external I/O for "stand alone" applications like driving tiny robots. Debug LED/Backlight LED support.
- Supports keyboard with real (moving) keys, using new keyboard overlay with holes for the keys, uses cheap 6x6mm buttons.
- Alternative (nicer) ZX15 font available, to replace the standard one in the ROM.
- Design files freely available (but do note that firmware is still © Amstrad!)
3D Preview of early ZX14
Before I even designed the PCB I made a mockup with Altium. Here are two (3D rendered) previews of the early ZX14 board, to the right a small preview of the complete system, including how I envisaged the whole system with keyboard would look like:
Schematic ZX14/ZX15
The latest schematic (.PDF) can be found here: Bestand:ZX14 schematic.pdf There is also a color coded schematic (.PDF), it can be found here: Bestand:Color coded ZX14 schematic with eprom support.pdf. Note that SMT components are depicted purple, and PTH ones green.
Layout ZX14
Even though I was hospitalized, then immobilized for several months (in the months of June July and August 2014) due to an operation on my leg, I still managed to work a bit on the layout of the ZX14. And on November 25, 2014 The layout work reached 100% connectivity. Here is a preview of how the work was progressed at that time . Clean-up, optimizing and copper filling followed somewhat later. The picture below on the left was actually a screen shot from a gerber viewer of how the board looked in September 16, 2014, note the lack of copper fill to make it easier to follow the connections around. Some weeks later the cleanup was ready, and this is a picture of how the PCB will more or less look like, when it is finished. Note the old PCB layout still had the, now defunct name "ZX81+34".
Keyboard (ZX14/ZX15)
Here is the schematic and board layout of the keyboard: Bestand:KB matrix schematic.pdf
The ZX15
Finally early January 2015 the PCB of the ZX15 was finished, some last minute changes were made to the silk screen, and some mounting holes were added (needed to mount in an enclosure, and to connect shielding, if you want to add that)
